Discuss
will not heat
 in
Dryer Repair
[FONT='Verdana','sans-serif']I have a Maytag dryer model MDE508DAYW that will not heat still under extended warranty/service contract. It stopped heating first
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » will not heat
  #1 (permalink)
Old 01-29-2010, 06:50 AM
Junior Member
johnstond is on a distinguished road
Default will not heat
Model Number: MDE508DAYW   Brand: Maytag   Age: 1 - 5 years
[FONT='Verdana','sans-serif']I have a Maytag dryer model MDE508DAYW that will not heat still under extended warranty/service contract. It stopped heating first repair man unplugged everything and tested and checked he said he could not find anything wrong so when he had put it all back together what a mystery it work. He said all he could figure was that some of the connections was corroded. It worked fine for 2 weeks then stopped heating again second repair man came out performed same things as the first finally said it was the timer had to order the next week a third different man came out installed the switch he started the dryer it ran for about 2 minutes said it was heating and working. The next day when my wife washed guess what? Dryer would not heat! Any ideas that I could test these goobers with? This will be the third separate / different call for the same thing. As I understand the "lemon law" if it is not corrected this time it should be replaced with an equal or comparable one correct?[/font]
[FONT='Verdana','sans-serif'][/font]
Related Models
Maytag MDE508DAYW DRYER- ELE
Frigidaire MDE546RED0 Frg(v1) / Electric Dryer
Frigidaire MDE546RED1 Frg(v1) / Electric Dryer
Frigidaire MDE546RES0 Frg(v2) / Electric Dryer
Frigidaire MDE546RES1 Frg(v2) / Electric Dryer
Frigidaire MDE546RET0 Frg(v3) / Electric Dryer
Frigidaire MDE546REW0 Frg(v4) / Electric Dryer
Frigidaire MDE546REW1 Frg(v3) / Electric Dryer
Maytag MDE5500AYQ DRYER- ELE
Maytag MDE5500AYW DRYER- ELE
Maytag MDE5500AZQ DRYER- ELE
Maytag MDE5500AZW DRYER- ELE
Maytag MDE5806AYK DRYER- ELE
Maytag MDE5806AYW DRYER- ELE
Maytag MDE5806AZK DRYER- ELE
Maytag MDE5806AZW DRYER- ELE
Maytag MDE5960AYW DRYER- ELE
Maytag MDE6000AUW DRYER- ELE
Maytag MDE6000AYQ DRYER- ELE
Maytag MDE6000AYW DRYER- ELE
Maytag MDE6000AZQ DRYER- ELE
Maytag MDE6000AZW DRYER- ELE
Maytag MDE6200AYQ DRYER- ELE
Maytag MDE6200AYW DRYER- ELE
Maytag MDE6200AZQ DRYER- ELE
Maytag MDE6200AZW DRYER- ELE
Maytag MDE6400AGW DRYER- ELE
Maytag MDE6400AYQ DRYER- ELE
Maytag MDE6400AYW DRYER- ELE
Maytag MDE6400AZW DRYER- ELE
Maytag MDE6460AYW DRYER- ELE
Maytag MDE6460AZW DRYER- ELE
Maytag MDE6657BYQ DRYER- ELE
Maytag MDE6657BYW DRYER- ELE
Maytag MDE6700AYW DRYER- ELE
Maytag MDE6700AZW DRYER- ELE
Maytag MDE6800AYQ DRYER- ELE
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
  #2 (permalink)
Old 01-29-2010, 01:10 PM
Junior Member
oilslinger53 is on a distinguished road
Default
Sounds like and intermittently loose connection somewhere...
  #3 (permalink)
Old 01-30-2010, 05:42 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
As oilslinger53 stated you probably have a bad connection somewhere.
The trick is finding it.
Each connector in the heater circuit has to be checked to make sure it is tight, properly crimped to the connector, etc.
The first place I would check is at the terminal strip in the unit, be sure to unplug the machine when doing this.
1 Once it starts a cycle and heats does it continue to operate correctly till the cycle is complete?
OR
2 Does it stop heating in the middle of a drying cycle?
If it is #1, I would suspect the centrifugal switch (for the heater) on the motor is not closing reliably.
Also are you changing the temperature setting.
If yes, it could be in the temperature switch
This site seems to have good info on Lemon laws
Lemon Law Summaries for each of the 50 States
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Normal Heat Empty, Heat Shuts Off Full BigDaddyG Dryer Repair 4 08-06-2009 03:17 PM
No Heat While Turning, Heat When Stopped thou msg2008 Dryer Repair 1 08-07-2008 05:08 AM
