Discuss
kenmore wont run
 in
Dryer Repair
My Kenmore gas dryer wasn’t turning on, it would sound like it was sending power to the motor but wouldn’t
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » kenmore wont run
  #1 (permalink)
Old 01-28-2010, 01:20 PM
Junior Member
tommetolius is on a distinguished road
Wink kenmore wont run
Model Number: 11076902690   Brand: Kenmore   Age: 1 - 5 years
My Kenmore gas dryer wasn’t turning on, it would sound like it was sending power to the motor but wouldn’t kick over. I checked the motor, it was seized, and I then replaced it. Now with the new motor as I plug the dryer in I get that same sound, as it power is being sent to the motor but it wont turn over. This happens even before I push the start button. If the timer is turned on and the door is shut, it sounds as power is being sent to a seized motor. Pushing the start button doesn’t change anything. The motor and fan and drum all spin very easily. Ok, I’ve checked the door switch 0 ohms. I think the broken belt switch is working properly, I’ve tried turning on the dryer with it unplugged and get nothing. The thermal fuse is good. There is an issue with the electrical because it tries to start before the start button is pushed. Any ideas???
Ads By Google
Related Models
Kenmore 11077401100 KENMORE GAS DRYER
Kenmore 11077401110 KENMORE GAS DRYER
Kenmore 11077401120 GAS DRYER
Kenmore 11077401400 KENMORE GAS DRYER
Kenmore 11077401410 KENMORE GAS DRYER
Kenmore 11077401420 GAS DRYER
Kenmore 11077401600 KENMORE GAS DRYER
Kenmore 11077401610 KENMORE GAS DRYER
Kenmore 11077401620 GAS DRYER
Kenmore 11077408160 GAS DRYER
Kenmore 11077408660 GAS DRYER
Kenmore 11077408860 GAS DRYER
Kenmore 11077409150 GAS DRYER
Kenmore 11077409650 GAS DRYER
Kenmore 11077409850 GAS DRYER
Kenmore 11077410100 KENMORE GAS DRYER
Kenmore 11077490100 KENMORE GAS DRYER
Kenmore 11077490200 KENMORE GAS DRYER
Kenmore 11077490400 KENMORE GAS DRYER
Kenmore 11077490600 KENMORE GAS DRYER
Kenmore 11077611100 KENMORE GAS DRYER
Kenmore 11077640100 KENMORE GAS DRYER
Kenmore 11077645100 KNEMORE GAS DRYER
Kenmore 11077675100 KENMORE GAS DRYER
Kenmore 11077675200 KENMORE GAS DRYER
Kenmore 11077675400 KENMORE GAS DRYER
Kenmore 11077675600 KENMORE GAS DRYER
Kenmore 11077732790 ELECTRIC DRYER
Kenmore 11077732791 GAS DRYER
Kenmore 11077732792 GAS DRYER
Kenmore 11077732794 GAS DRYER
Kenmore 11077732795 GAS DRYER
Kenmore 11077832790 ELECTRIC DRYER
Kenmore 11077832791 GAS DRYER
Kenmore 11077832792 GAS DRYER
Kenmore 11077832794 GAS DRYER
Kenmore 11077832795 GAS DRYER
Kenmore 11077834790 GAS DRYER
Kenmore 11077834791 GAS DRYER
Kenmore 11077834794 GAS DRYER
Kenmore 11077834795 GAS DRYER
Kenmore 11078202790 GAS DRYER
Kenmore 11078202794 GAS DRYER
Kenmore 11078202795 GAS DRYER
Kenmore 11078410100 KENMORE ELECTRIC DRYER
Kenmore 11078410110 KENMORE ELECTRIC DRYER
Kenmore 11078410200 KENMORE ELECTRIC DRYER
Kenmore 11078410210 KENMORE ELECTRIC DRYER
Kenmore 11078410400 KENMORE ELECTRIC DRYER
Kenmore 11078410410 KENMORE ELECTRIC DRYER
Kenmore 11078410600 KENMORE ELECTRIC DRYER
Kenmore 11078410610 KENMORE ELECTRIC DRYER
Kenmore 11078411100 KENMORE ELECTRIC DRYER
Kenmore 11078411110 KENMORE ELECTRIC DRYER
Kenmore 11078411200 KENMORE ELECTRIC DRYER
Kenmore 11078411210 KENMORE ELECTRIC DRYER
Kenmore 11078411400 KENMORE ELECTRIC DRYER
Kenmore 11078411410 KENMORE ELECTRIC DRYER
Kenmore 11078411600 KENMORE ELECTRIC DRYER
Kenmore 11078411610 KENMORE ELECTRIC DRYER
Kenmore 11078412100 KENMORE ELECTRIC DRYER
Kenmore 11078412200 KENMORE ELECTRIC DRYER
Kenmore 11078412400 KENMORE ELECTRIC DRYER
Kenmore 11078412600 KENMORE ELECTRIC DRYER
Kenmore 11078413100 KENMORE ELECTRIC DRYER
Kenmore 11078413200 KENMORE ELECTRIC DRYER
Kenmore 11078413400 KENMORE ELECTRIC DRYER
Kenmore 11078413600 KENMORE ELECTRIC DRYER
Kenmore 11078413800 KENMORE ELECTRIC DRYER
Kenmore 11078414100 KENMORE ELECTRIC DRYER
Kenmore 11078414200 KENMORE ELECTRIC DRYER
Kenmore 11078414400 KENMORE ELECTRIC DRYER
Kenmore 11078414600 KENMORE ELECTRIC DRYER
Kenmore 11078414800 KENMORE ELECTRIC DRYER
Kenmore 11078415100 ELECTRIC DRYER
Kenmore 11078415110 ELECTRIC DRYER
Kenmore 11078415120 ELECTRIC DRYER
Kenmore 11078415200 ELECTRIC DRYER
Kenmore 11078415210 ELECTRIC DRYER
Kenmore 11078415220 ELECTRIC DRYER
Kenmore 11078415400 ELECTRIC DRYER
Kenmore 11078415410 ELECTRIC DRYER
Kenmore 11078415420 ELECTRIC DRYER
Kenmore 11078415600 ELECTRIC DRYER
Kenmore 11078415610 ELECTRIC DRYER
Kenmore 11078415620 ELECTRIC DRYER
Kenmore 11078415800 ELECTRIC DRYER
Kenmore 11078415810 ELECTRIC DRYER
Kenmore 11078702890 ELECTRIC DRYER
Kenmore 11079082990 COMMERICAL GAS DRYER
Kenmore 11079202990 GAS DRYER
Kenmore 11079495100 KENMORE COMPACT GAS DRYER
Kenmore 11079495110 KENMORE GAS DRYER
Kenmore 11079495200 KENMORE COMPACT GAS DRYER
Kenmore 11079495210 KENMORE GAS DRYER
Kenmore 11079495400 KENMORE COMPACT GAS DRYER
Kenmore 11079495410 KENMORE GAS DRYER
Kenmore 11079495600 KENMORE COMPACT GAS DRYER
Kenmore 11079495610 KENMORE GAS DRYER
Kenmore 11079496100 SEARS KENMORE GAS DRYER
Kenmore 11079496110 KENMORE GAS DRYER
Kenmore 11079496200 SEARS KENMORE GAS DRYER
Kenmore 11079496210 KENMORE GAS DRYER
Kenmore 11079496400 SEARS KENMORE GAS DRYER
Kenmore 11079496410 KENMORE GAS DRYER
Kenmore 11079496600 SEARS KENMORE GAS DRYER
Kenmore 11079496610 KENMORE GAS DRYER
Kenmore 11079812990 GAS DRYER
Kenmore 11079902890 GAS DRYER
Kenmore 11079912990 GAS DRYER
Kenmore 11080094 AUTOMATIC WASHER GEAR CASE AND SUPERSTRUCTURE
Kenmore 11080252 DOLE MIXING VALVE ASSEMBLY
Kenmore 11080364 MIXING VALVE ASSEMBLY
Kenmore 11080609 MIXING VALVE ASSEMBLY
Kenmore 11080671 MIXING VALVE ASSEMBLY
Kenmore 11080754000 WASHER-DRYER LAUNDRY SYSTEM
Kenmore 11080754001 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11080764000 WASHER-DRYER LAUNDRY SYSTEM
Kenmore 11080881 FULTON SYLPHON MIXING VALVE ASSEMBLY
Kenmore 11080947 MIXING VALVE ASSEMBLY
  #2 (permalink)
Old 01-28-2010, 03:41 PM
Junior Member
Default well maybe we all learned something
Ok, I grabbed the old motor cleaned it up and noticed the prong labeled #6 that I thought the “broken belt” wire attached to was coated in lint, however the #4 prong was shiny and new leading me to believe that it was in fact the #4 prong that was covered for the last 5 years. Apparently I screwed up when writing this down. I attached the yellow “broken belt” wire to the #4 prong and she worked.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore dryer wont dry jimbo007 Dryer Repair 0 11-06-2009 07:11 PM
Kenmore Elite-water wont shut off, now wont drain or spin dbigotis Washer Repair 1 05-12-2009 04:27 PM
Kenmore Elite-water wont shut off, now wont drain dbigotis Washer Repair 1 05-12-2009 04:26 PM
Kenmore wont' wash val21496 Dishwasher Repair 2 05-25-2008 06:09 PM
kenmore wont work gatemindr1 Dishwasher Repair 0 01-26-2008 06:16 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
