| » dryer not heating well |
The most common cause is a dirty vent system
Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully. If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load. Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
__________________
| Display Modes | |
| Dryer not heating | rcabalo | Dryer Repair | 2 | 11-26-2009 09:52 AM |
| dryer not heating | iyacko | Dryer Repair | 2 | 08-26-2009 12:50 PM |
| dryer not heating | ecubulldog | Dryer Repair | 1 | 07-05-2009 07:40 AM |
| Dryer not Heating | stompy27 | Dryer Repair | 0 | 11-05-2008 06:06 AM |
| Gas dryer not heating | Penthor | Dryer Repair | 3 | 02-17-2008 08:56 AM |
