Discuss
wHIRLPOOL dRYER NEEDS HELP
 in
Dryer Repair
I Have A Whirlpool Dryer That The Heat Will Not Work After 10 Minutes Of Running. The Dryer Vent Was
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » wHIRLPOOL dRYER NEEDS HELP
  #1 (permalink)
Old 04-17-2008, 04:24 PM
WAYNE JAROSH WAYNE JAROSH is offline
Junior Member
WAYNE JAROSH is on a distinguished road
Smile wHIRLPOOL dRYER NEEDS HELP
Model Number: LGR7646JT0   Brand: Whirlpool   Age: 5 - 10 years
I Have A Whirlpool Dryer That The Heat Will Not Work After 10 Minutes Of Running. The Dryer Vent Was Full And I Cleaned That Out. I Cleaned The Back Of The Unit Also. I Think There May Be A Hi-limit Switch That May Be Out. If I Let The Dryer Set For 15 Minutes It Will Work Again For 10 Minutes And Heat Will Become Cold. Can Anyone Help?
Wayne
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-17-2008, 08:00 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
turn on dryer .go out side +check for good air exhaust, also kinked venting at back of dryer,it could also be timer contact problem
__________________
  #3 (permalink)
Old 07-31-2008, 09:51 PM
SublimeMasterJW SublimeMasterJW is offline
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default electrical problem
Could be a bad breaker.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer DanaNicholson Dryer Repair 4 02-03-2008 04:44 PM
Whirlpool gas dryer Paul Solarz Dryer Repair 3 12-16-2007 03:25 PM
Whirlpool Dryer babe milam Dryer Repair 1 11-14-2007 01:52 PM
Whirlpool Dryer babe milam Dryer Repair 1 11-14-2007 12:46 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
