Discuss
no heat in dryer
 in
Dryer Repair
this is an electric dryer ,whirlpool that does not heat up. i replaced the heating element but it did not
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » no heat in dryer
  #1 (permalink)
Old 01-26-2010, 05:58 AM
Junior Member
bill52387 is on a distinguished road
Unhappy no heat in dryer
Model Number: lec6848an1   Brand: Whirlpool   Age: 5 - 10 years
i replaced the heating element but it did not solve the problem,please help!!!
Related Models
Whirlpool LEC6848AN1 ELECTRIC DRYER
Whirlpool LEC6848AN2 ELECTRIC DRYER
Whirlpool LEC6848AN3 ELECTRIC DRYER
Whirlpool LEC6848AQ0 Residential Dryer
Whirlpool LEC6848AQ1 ELECTRIC DRYER
Whirlpool LEC6848AQ2 ELECTRIC DRYER
Whirlpool LEC6848AQ3 ELECTRIC DRYER
Whirlpool LEC6848AW0 ELECTRIC DRYER
Whirlpool LEC6848AW1 TECH SHEET - DRYER - REVISION REL.
Whirlpool LEC6848AW2 ELECTRIC DRYER
Whirlpool LEC6848AW3 ELECTRIC DRYER
Whirlpool LEC6848AZ1 ELECTRIC DRYER
Whirlpool LEC6848AZ2 ELECTRIC DRYER
Whirlpool LEC6848AZ3 ELECTRIC DRYER
Whirlpool LEC6858AQ3 ELECTRIC DRYER
Whirlpool LEC7646DQ0 ELECTRIC DRYER
Whirlpool LEC7646DQ1 ELECTRIC DRYER
Whirlpool LEC7646DZ0 ELECTRIC DRYER
Whirlpool LEC7646DZ1 ELECTRIC DRYER
Whirlpool LEC7848DQ0 ELECTRIC DRYER
Whirlpool LEC7848DQ1 ELECTRIC DRYER
Whirlpool LEC7848DZ0 ELECTRIC DRYER
Whirlpool LEC7848DZ1 ELECTRIC DRYER
Whirlpool LEC7858AN0 ELECTRIC DRYER
Whirlpool LEC7858AN1 ELECTRIC DRYER
Whirlpool LEC7858AN2 ELECTRIC DRYER
Whirlpool LEC7858AQ0 ELECTRIC DRYER
Whirlpool LEC7858AQ1 ELECTRIC DRYER
Whirlpool LEC7858AQ2 ELECTRIC DRYER
Whirlpool LEC7858AW0 Residential Dryer
Whirlpool LEC7858AW1 ELECTRIC DRYER
Whirlpool LEC7858AW2 ELECTRIC DRYER
Whirlpool LEC7858AZ0 ELECTRIC DRYER
Whirlpool LEC7858AZ1 ELECTRIC DRYER
Whirlpool LEC7858AZ2 ELECTRIC DRYER
Amana LEC80AW DRYER- ELE
Whirlpool LEC8858DQ0 ELECTRIC DRYER
Whirlpool LEC8858DQ1 ELECTRIC DRYER
Whirlpool LEC8858DZ0 ELECTRIC DRYER
Whirlpool LEC8858DZ1 ELECTRIC DRYER
Whirlpool LEC8858EQ0 ELECTRIC DRYER
Whirlpool LEC8858EQ1 DRYERS
Whirlpool LEC8858EQ2 ELECTRIC DRYER
Whirlpool LEC8858EZ0 ELECTRIC DRYER
Whirlpool LEC8858EZ1 DRYERS
Whirlpool LEC8858EZ2 ELECTRIC DRYER
Whirlpool LEC9000PW0 29" ELECTRIC DRYER
Whirlpool LEC9000PW1 29" ELECTRIC DRYER
Amana LEC90AW DRYER- ELE
Frigidaire LECR23EFE0 Frigidaire/refrigerator
Frigidaire LECR23EFE1 REFRIGERATOR
Frigidaire LECR23EFE2 REFRIGERATOR
Frigidaire LECR23EFE3 REFRIGERATOR
Amana LED20AW DRYER- ELE
Amana LED250 WASHER-TOP LOADING
Amana LED250 DRYER- ELE
Amana LED302 DRYER- ELE
Amana LED302 WASHER-TOP LOADING
Amana LED32AW DRYER- ELE
Amana LED450 WASHER-TOP LOADING
Amana LED450 DRYER- ELE
Amana LED502 DRYER- ELE
Amana LED57AW DRYER- ELE
Amana LED65AW DRYER- ELE
Amana LED850 WASHER-TOP LOADING
Amana LED850 DRYER- ELE
Amana LED902 DRYER- ELE
Amana LED950 WASHER-TOP LOADING
Amana LED950 DRYER- ELE
Frigidaire LEDB400FEE0 Frigidaire/dishwasher
Frigidaire LEDB500FEE0 Frigidaire Elements/dishwasher
Whirlpool LEE9848BQ0 ELECTRIC DRYER
Whirlpool LEE9848BQ1 ELECTRIC DRYER
Whirlpool LEE9848BQ2 ELECTRIC DRYER
Whirlpool LEE9848BZ0 ELECTRIC DRYER
Whirlpool LEE9848BZ1 ELECTRIC DRYER
Whirlpool LEE9848BZ2 ELECTRIC DRYER
Frigidaire LEEB30S9FEA Frigidaire/wall Oven
Frigidaire LEEB30T9FEA Frigidaire/wall Oven
Frigidaire LEEC30S9FEA Frigidaire/cooktop
Frigidaire LEEC36S9FEA Frigidaire/cooktop
Frigidaire LEEFM389FEA Frigidaire/electric Range
Frigidaire LEEFM389FEB Frigidaire/electric Range
Frigidaire LEEFM389FEF ELECTRIC RANGE
Whirlpool LEG8858JZ0 ELECTRIC DRYER
Frigidaire LEGC30S9FEA Frigidaire/gas Cooktop
Frigidaire LEGC36S9FEA Frigidaire/gas Cooktop
Frigidaire LEGFM389FEA Frigidaire/gas Range
Frigidaire LEH1642DS0 Frigidaire/laundry Center
Whirlpool LEL7646EQ0 DRYER
Whirlpool LEL7646EQ1 DRYERS
Whirlpool LEL8858DQ0 ELECTRIC DRYER
Whirlpool LEL8858DZ0 ELECTRIC DRYER
Whirlpool LEL8858EQ0 DRYER
Whirlpool LEL8858EQ1 DRYERS
Whirlpool LEL8858EQ2 ELECTRIC DRYER
General Electric LEM045H01 Electric range
General Electric LEM045H02 Counter top microwave
General Electric LEM045H03 Counter top microwave
General Electric LEM045J01 Counter top microwave
General Electric LEM045J02 Counter top microwave
General Electric LEM045J03 Counter top microwave
General Electric LEM065H01 Electric range
General Electric LEM085H01 Electric range
Amana LEM427L DRYER- ELE
Amana LEM427W DRYER- ELE
Amana LEM437L DRYER- ELE
Amana LEM437W DRYER- ELE
Amana LEM447L DRYER- ELE
Amana LEM447W DRYER- ELE
Amana LEM547L DRYER- ELE
Amana LEM547W DRYER- ELE
Amana LEM847W DRYER- ELE
Whirlpool LEN1000HQ0 ELECTRIC DRYER
Whirlpool LEN1000HQ1 ELECTRIC DRYER
Whirlpool LEN1000PQ0 29"ELECTRIC DRYER
Whirlpool LEN1000PQ1 29"ELECTRIC DRYER
  #2 (permalink)
Old 01-27-2010, 04:59 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for WHIRLPOOL LEC6848AN1 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/w...%203398692.pdf
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
