jjohnson3275@charter.net Trying to replace drive belt, but replacement belt too long (I have the correct belt). Diagram for motor pulley with tension pulley are reversed from what I'm seeing. Diagram shows tension pulley to left of motor looking from the rear. My dryer uses tension rod , not spring, and tension pulley is next to side housing or right of motor which gives no belt tension and will not activate microswitch. Is something missing? I just can't believe the tension rod is bent, especially that much (2" or more). jimj3275
