Discuss
Frigidaire Gas Dryer - heat inconsistent
 in
Dryer Repair
I just replaced ignitor - but after a full cycle at HOT it still has wet clothes. In two cycles of
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire Gas Dryer - heat inconsistent
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-14-2008, 08:55 AM
futbol79 futbol79 is offline
Junior Member
futbol79 is on a distinguished road
Default Frigidaire Gas Dryer - heat inconsistent
Model Number: GLGR331AS1   Brand: Frigidaire   Age: 5 - 10 years
I just replaced ignitor - but after a full cycle at HOT it still has wet clothes. In two cycles of 70 minutes each it drys.
It starts the gas burner - but I suspect that it shuts off early.
What do I need to fix this?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-14-2008, 09:49 AM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Before getting into the dryer itself it
would be a good idea to thoroughly check the venting and
make sure the outside vent hood is fully opening.
A restriction can cause the burner to shut down before
drum comes up to the right temperature.
  #3 (permalink)
Old 04-14-2008, 11:29 AM
Junior Member
Default
I have the entire path clean as a whistle
  #4 (permalink)
Old 04-15-2008, 02:23 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
With damp,cold clothes in the dryer, the flame should stay on till the clothes heat up, more than 5 minutes, if not, you probably have bad gas valve coils.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire gas dryer has no heat chevyguy Dryer Repair 0 03-01-2008 10:06 PM
Frigidaire Electric Oven Doesn't Heat sharzaz Oven Repair (including Ranges and Cooktops) 7 02-09-2008 04:07 PM
Frigidaire Gas Dryer works but No Heat, Why?? mvetri Dryer Repair 3 11-02-2007 03:46 PM
dryer heat is inconsistent sblylck Dryer Repair 1 10-25-2007 02:27 AM
Inconsistent temperature frig & freez vrocrider Refrigerator & Freezer Repair 1 09-14-2007 02:09 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
