Discuss
GE Dryer want heat
 in
Dryer Repair
My heating element want heat up. Everything shows to be working. How do you know when the safety switches are
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE Dryer want heat
  #1 (permalink)
Old 04-13-2008, 10:37 PM
rmurphy65692 rmurphy65692 is offline
Junior Member
rmurphy65692 is on a distinguished road
Default GE Dryer want heat
Model Number: DPSR483EA1WW   Brand: GE   Age: 1 - 5 years
My heating element want heat up. Everything shows to be working. How do you know when the safety switches are not working? I have power on both sides of the switches. Not sure if they are normally open or closed switches. The heating elements look but not sure about them either with out taking the dryer all the way apart. Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-14-2008, 04:47 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Probably a blown thermal fuse. If you lift the top, you will find it on top of the shroud in the back.
__________________
  #3 (permalink)
Old 04-14-2008, 06:56 AM
kayakcrzy kayakcrzy is offline
Senior Expert
APP Volunteer
kayakcrzy is on a distinguished road
Default
You might want to check your breaker, it might be partially tripped. Voltage flows to the path of least resistance, and will send power to the motor. You also might want to check, where the plug goes into the dryer, and see if there are no burn't wires, which is a great place for you to get your volt meter, and check accross the line to make sure you have 240 volts. If so, unplug the dryer, and pop the top, and check those thermostats up top, on you ohms scale for continuity. If you don't get a reading replace it. After all that, you will have to take the unit apart to check the element. Tom ApplianceEducator.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 04:50 PM
gas dryer no heat help jlrskymaster Dryer Repair 1 03-14-2008 06:32 PM
Dryer won't heat tomhickey Dryer Repair 1 12-23-2007 11:41 AM
No Heat dryer chaionsaw Dryer Repair 3 12-22-2007 03:37 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 11:47 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
