| » Dryer wont turn on |
Model Number: Ler3624eq1 Brand: Whirlpool Age: 5 - 10 years
Our Dryer wont turn, When you push the start button nothing happens. Do you have any advice. Thanks
Could be a few things.
1. Have you got 220 volts? 2. If you have proper voltage check your door switch for continuity. If the switch doesn't close the circuit when the door is closed the dryer won't work. 3. Check your thermal fuse for continuity. Should have continuity, if not replace it. If it's not one of those three things, check back. |
hey gearhead 1218
thanks for your advice--but no go. We have 220. I am quite green so dont understand the concept of "continuity". I have located the thermal fuse but again dont grasp how i would properly check for continuity. thanks! |
| Display Modes | |
| dryer wont turn | fastfreddie68 | Dryer Repair | 1 | 02-02-2010 02:46 AM |
| dryer wont turn on | jake@studioyoshida.com | Dryer Repair | 1 | 11-10-2009 04:18 PM |
| Dryer wont turn | yumickapowell | Dryer Repair | 1 | 09-20-2009 03:29 AM |
| Dryer wont turn on | delank | Dryer Repair | 5 | 09-02-2009 06:51 PM |
| Dryer wont turn on | angierg | Dryer Repair | 0 | 09-04-2007 03:52 PM |
