Discuss
Dryer wont turn on
 in
Dryer Repair
Our Dryer wont turn, When you push the start button nothing happens. Do you have any advice. Thanks Ads By
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer wont turn on
  #1 (permalink)
Old 04-13-2008, 04:53 PM
Junior Member
Julierob is on a distinguished road
Default Dryer wont turn on
Model Number: Ler3624eq1   Brand: Whirlpool   Age: 5 - 10 years
Ads By Google
Related Models
Whirlpool LER3624EQ1 ELECTRIC DRYER
Whirlpool LER3624JQ0 DRYER
Whirlpool LER3624JQ1 RESIDENTIAL DRYER
Whirlpool LER3624JQ2 29" ELECTRIC DRYER
Whirlpool LER3624PQ0 29" ELECTRIC DRYER
Whirlpool LER3624PQ1 29" ELECTRIC DRYER
Whirlpool LER3634EW0 ELECTRIC DRYER
Whirlpool LER3634EW1 DRYERS
Whirlpool LER3634EW2 ELECTRIC DRYER
Whirlpool LER3634JW0 ELECTRIC DRYER
Whirlpool LER3634JW1 RESIDENTIAL DRYER
Admiral LER3725AAC RANGE- S/C F/S ELE
Whirlpool LER4434AN0 ELECTRIC DRYER
Whirlpool LER4434AN1 ELECTRIC DRYER
Whirlpool LER4434AQ0 Residential Dryer
Whirlpool LER4434AQ1 ELECTRIC DRYER
Whirlpool LER4434AW0 Residential Dryer
Whirlpool LER4434AW1 ELECTRIC DRYER
Whirlpool LER4436AW0 Residential Dryer
Whirlpool LER4600PQ0 29" ELECTRIC DRYER
Whirlpool LER4600PQ1 29" ELECTRIC DRYER
Whirlpool LER4624BN0 ELECTRIC DRYER
Whirlpool LER4624BN1 ELECTRIC DRYER
Whirlpool LER4624BN2 ELECTRIC DRYER
Whirlpool LER4624BQ0 ELECTRIC DRYER
Whirlpool LER4624BQ1 ELECTRIC DRYER
Whirlpool LER4624BQ2 ELECTRIC DRYER
Whirlpool LER4624BW0 ELECTRIC DRYER
Whirlpool LER4624BW1 ELECTRIC DRYER
Whirlpool LER4624BW2 ELECTRIC DRYER
Whirlpool LER4624DQ0 ELECTRIC DRYER
Whirlpool LER4624DQ1 ELECTRIC DRYER
Whirlpool LER4624DZ0 ELECTRIC DRYER
Whirlpool LER4624DZ1 ELECTRIC DRYER
Whirlpool LER4634BQ0 ELECTRIC DRYER
Whirlpool LER4634BQ1 ELECTRIC DRYER
Whirlpool LER4634BQ2 ELECTRIC DRYER
Whirlpool LER4634DQ0 DRYERS
Whirlpool LER4634DQ1 ELECTRIC DRYER
Whirlpool LER4634DZ0 DRYERS
Whirlpool LER4634DZ1 ELECTRIC DRYER
Whirlpool LER4634EQ0 ELECTRIC DRYER
Whirlpool LER4634EQ1 DRYERS
Whirlpool LER4634EQ2 ELECTRIC DRYER
Whirlpool LER4634EW0 ELECTRIC DRYER
Whirlpool LER4634EZ0 ELECTRIC DRYER
Whirlpool LER4634EZ1 DRYERS
Whirlpool LER4634EZ2 ELECTRIC DRYER
Whirlpool LER4634JQ0 ELECTRIC DRYER
Whirlpool LER4634JQ1 RESIDENTIAL DRYER
Whirlpool LER4634JQ2 29" ELECTRIC DRYER
Whirlpool LER4634JT0 ELECTRIC DRYER
Whirlpool LER4634JT1 RESIDENTIAL DRYER
Whirlpool LER4634JT2 29" ELECTRIC DRYER
Whirlpool LER4634JZ0 ELECTRIC DRYER
Whirlpool LER4634PQ0 29" ELECTRIC DRYER
Whirlpool LER4634PQ1 29" ELECTRIC DRYER
Whirlpool LER4634PT0 29" ELECTRIC DRYER
Whirlpool LER4634PT1 29" ELECTRIC DRYER
Whirlpool LER5434AW0 Residential Dryer
Whirlpool LER5600HQ0 ELECTRIC DRYER
Whirlpool LER5600HZ0 ELECTRIC DRYER
Whirlpool LER5600JQ0 ELECTRIC DRYER
Whirlpool LER5600JT0 ELECTRIC DRYER
Whirlpool LER5620KQ0 RESIDENTIAL DRYER
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
Whirlpool LER5624BW1 ELECTRIC DRYER
Whirlpool LER5624BW2 ELECTRIC DRYER
Whirlpool LER5624DQ0 DRYERS
Whirlpool LER5624DQ1 ELECTRIC DRYER
Whirlpool LER5624DW1 ELECTRIC DRYER
Whirlpool LER5624DZ0 DRYERS
Whirlpool LER5624DZ1 ELECTRIC DRYER
Whirlpool LER5634AN0 ELECTRIC DRYERS
Whirlpool LER5634AQ0 ELECTRIC DRYER
Whirlpool LER5634AQ1 ELECTRIC DRYER
Whirlpool LER5634AQ2 ELECTRIC DRYER
Whirlpool LER5634AW0 ELECTRIC DRYERS
Whirlpool LER5634DQ1 DRYER
Whirlpool LER5634EQ0 ELECTRIC DRYER
Whirlpool LER5634EZ0 ELECTRIC DRYER
Whirlpool LER5634LG0 RESIDENTIAL DRYER
Whirlpool LER5634LQ0 29" ELECTRIC DRYER
Whirlpool LER5634LT0 RESIDENTIAL DRYER
Whirlpool LER5634LW0 RESIDENTIAL DRYER
Whirlpool LER5635LQ0 29"ELECTRIC DRYER
Whirlpool LER5635LQ1 29"ELECTRIC DRYER
Whirlpool LER5636DW0 ELECTRIC DRYER
Whirlpool LER5636DW1 ELECTRIC DRYER
Whirlpool LER5636EQ0 ELECTRIC DRYER
Whirlpool LER5636EQ1 ELECTRIC DRYER
Whirlpool LER5636EQ2 ELECTRIC DRYER
Whirlpool LER5636EQ3 ELECTRIC DRYER
Whirlpool LER5636EZ0 ELECTRIC DRYER
Whirlpool LER5636EZ01 ELECTRIC DRYER
Whirlpool LER5636EZ1 DRYER
Whirlpool LER5636EZ2 ELECTRIC DRYER
Whirlpool LER5636EZ3 ELECTRIC DRYER
Whirlpool LER5636JQ0 ELECTRIC DRYER
Whirlpool LER5636JT0 ELECTRIC DRYER
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
  #2 (permalink)
Old 04-14-2008, 02:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would check is 240V at the power outlet (120V between any hot and neutral and 240V between two hot).
If there is no 240V then check the circuit breakers.
If there is 240V then remove the rear cover from the dryer and check the thermal fuse for continuity (#23 on the break down diagram).
If the thermal fuse is open - it has to be replaced together with the cycling thermostat (#24 on the break down diagram).
- The part number for the thermal fuse is AP3132867
- The part number for the cycling thermostat is AP3115922
Here are the break down diagrams for the Whirlpool dryer Model LER3624EQ1
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-14-2008, 02:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer wont turn fastfreddie68 Dryer Repair 1 02-02-2010 02:46 AM
dryer wont turn on jake@studioyoshida.com Dryer Repair 1 11-10-2009 04:18 PM
Dryer wont turn yumickapowell Dryer Repair 1 09-20-2009 03:29 AM
Dryer wont turn on Julierob Dryer Repair 3 04-14-2008 03:40 AM
Dryer wont turn on angierg Dryer Repair 0 09-04-2007 03:52 PM
