Discuss
Replaced Thermistor still getting E1 error code
 in
Dryer Repair
I replaced a bad motor Dryer will run for about 30 seconds received E1 error code Replaced Thermistor now dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Replaced Thermistor still getting E1 error code
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-11-2008, 09:09 AM
AGF AGF is offline
Junior Member
AGF is on a distinguished road
Post Replaced Thermistor still getting E1 error code
Model Number: GEW9200LWO   Brand: Whirlpool   Age: 1 - 5 years
I replaced a bad motor Dryer will run for about 30 seconds received E1 error code Replaced Thermistor now dryer runs for about 30 seconds still turns off and displays E1 error code. What do I do now?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-11-2008, 04:15 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The "E1" error code means the thermistor is open but it could be also a broken wire, loose connections at the teamster and/or the control board and a bad control board.
The first thing I would do is run the test #3a as described in the tech sheets, check all wires and , if there is nothing wrong, replace the control board.
Here are the break down diagrams for the Whirlpool dryer Model GEW9200LW0
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE error code F3 Mako Oven Repair (including Ranges and Cooktops) 20 04-10-2008 09:03 PM
GE F3 sensor replaced but still get error F3 dpmath Oven Repair (including Ranges and Cooktops) 1 04-02-2008 05:45 AM
f10 error code lindi Oven Repair (including Ranges and Cooktops) 3 01-16-2008 11:00 AM
Error Code F2 startz Oven Repair (including Ranges and Cooktops) 1 12-21-2007 10:05 AM
F2 - Error Code Wilson Oven Repair (including Ranges and Cooktops) 3 08-23-2007 09:49 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
