Discuss
Dryer will not run
 in
Dryer Repair
Kenmore dryer will not start, I have tested the thermal fuse, the thermostat, and the heating element. I have tested
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will not run
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-08-2008, 05:34 PM
jlrobin01 jlrobin01 is offline
Junior Member
jlrobin01 is on a distinguished road
Default Dryer will not run
Model Number: 110-96292800   Brand: Kenmore   Age: More than 10 years
Kenmore dryer will not start, I have tested the thermal fuse, the thermostat, and the heating element. I have tested for 240 volts at the wall plug and the connection block in the dryer. The only thing left to test is the Timer Switch and how do you test it just because the clock works does not mean the power is making contact internally.
Last edited by jlrobin01 : 04-13-2008 at 11:15 AM. Reason: Tested part with volt ohm meter.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-09-2008, 03:07 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the thermal fuse. It's located on the blower wheel cover behind the front panel.
Replace the thermal fuse if it's open.
- The part number for the thermal fuse is AP3133489
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
