Discuss
Whirlpool Auto / Accudry Never Stops
 in
Dryer Repair
I have a Whirlpool WED5840SW0 that runs great on timed dry, but when set on Accudry (auto) it never advances
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Auto / Accudry Never Stops
  #1 (permalink)
Old 04-07-2008, 03:14 PM
zds zds is offline
Junior Member
zds is on a distinguished road
Default Whirlpool Auto / Accudry Never Stops
Model Number: WED5480SW0   Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool WED5840SW0 that runs great on timed dry, but when set on Accudry (auto) it never advances or stops (I did a test run and confirmed the problem with a wet towel - it will just fry the items...). The auto dial never advances.
The vent is oversized and clear (military housing - government contracting at its best).
I just finished checking all the thermostats - they're all closed (0 ohms) when cold and the bias (operating) thermostat clicks and shows resistance when heated over the stove.
However, the loop from 120v to control panel goes through the motor, where it does not show 0 ohm (so something is open at the motor). From best I can tell this means that I do not need a new thermostat, but does it point to the timer? After all, it works fine on timed dry mode...
Also, when the thermostat loop (red wire) is disconnected from the timer, the dryer spins by the heater doesn't turn on at all...
Is there a way I can test the timer?
Or does anyone have any better advice?
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-07-2008, 03:58 PM
zds zds is offline
Junior Member
Default
Another data point: The operating thermostat definitely works - I just ran the dryer in auto on high and disconnected from the vent. With a cooking thermometer I measured the temp get up to 155-160 and then heard the operating thermostat click open and watched the exhaust temp drop.
However, the dial never moved! So, is this definitive evidence that the timer is shot, or is there a better test?
Thanks!
  #3 (permalink)
Old 04-07-2008, 05:34 PM
zds zds is offline
Junior Member
Default
Continuing my research I realized that the timer motor was getting 120v in timed mode, but not in auto mode (the two black wires running into the motor part of the timer). A closer inspection revealed that the circuit board wasn't properly seated in its slot.
One good push and 120v appeared across those black lines, and low and behold the dial advances in auto as the operating thermo cycles!
Huzzah!
  #4 (permalink)
Old 04-08-2008, 02:44 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Good job!
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven not working after auto clean lhensley Oven Repair (including Ranges and Cooktops) 3 02-04-2008 07:24 PM
Auto-Defrost not working? aimmer Refrigerator & Freezer Repair 1 01-10-2008 08:27 PM
Amana ALE866SAW not auto drying murdstone Washer Repair 1 01-09-2008 02:39 PM
D/W won't cycle auto but will manually jld8996 Dishwasher Repair 1 01-08-2008 05:44 PM
Auto Moisture Sensing Plus not working mschmero Dryer Repair 2 01-06-2008 12:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
