| » Gas dryer with low heat and large hot flame |
Model Number: DG712 Brand: Maytag Age: 5 - 10 years
I purchased a home recently and it came with Maytag gas dryer (Model DG712) that looks essentially new and little used. The location of the dryer was changed and it has brand new exhaust ducting and good flow. My problem is that the dryer heat (i.e.flame) cycles on and off because of the Hi-Limit thermostat on the flame chamber and it turns the flame off too soon, i.e. before there is adequately heated air. It takes 3 or 4 50 minute cycles to dry an average load. If I remove the Hi-Limit Thermostat from its position and just set it inside the dryer body, the dryer works fine. The thermostats turn the flame on and off and the clothes dry in a resonable length of time--about 50". So, I replaced the Hi-Limit Thermostat and the Flame Sensor with new parts--but--the dryer behaves exactly the same way! The flame actually reaches the Hi-Limit Thermostat so it does not surprise me that it triggers and turns off the flame. Could the flame be too hot or too large? The tips of the flame also reach the back of the dryer (on the inside). What components determine the size and temperature of the flame? I think the flame is too large. Any advice would be appreciated.
If you are using propane, you have a defective regulator on the bottle. If that's ok, you might have a gas valve orifice for natural gas and you are using propane.
__________________
| Display Modes | |
| Gas dryer ran but not heat. After testing and replacing the flame sensor, the proble | yzhong | Dryer Repair | 0 | 08-26-2009 02:33 PM |
| No Heat And Flame | dman1966 | Dryer Repair | 1 | 12-30-2008 01:45 PM |
| Large oven flame | bobcatjay | Oven Repair (including Ranges and Cooktops) | 2 | 12-09-2008 07:18 AM |
| sealed cooktop burners low flame large burners only | heavy chevy | Oven Repair (including Ranges and Cooktops) | 3 | 12-22-2007 08:37 AM |
| sealed cooktop burners low flame large burners only | heavy chevy | Oven Repair (including Ranges and Cooktops) | 0 | 12-21-2007 05:36 PM |
