Discuss
amana no heat...checking 3 prong thermostat
 in
Dryer Repair
on a 3 prong thermostat should you be able to get continuity on small prong with one of the larger
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » amana no heat...checking 3 prong thermostat
  #1 (permalink)
Old 01-15-2010, 01:50 PM
Junior Member
blu42nite is on a distinguished road
Default amana no heat...checking 3 prong thermostat
Model Number: le8317w2   Brand: Amana   Age: 5 - 10 years
on a 3 prong thermostat should you be able to get continuity on small prong with one of the larger side prongs?
Related Models
Amana LE8317W2 DRYER- ELE
Amana LE8317W2B DRYER- ELE
Amana LE8327W DRYER- ELE
Amana LE8367L2 WASHER-TOP LOADING
Amana LE8367W2 DRYER- ELE
Amana LE8407L2 DRYER- ELE
Amana LE8407W DRYER- ELE
Amana LE8407W2 DRYER- ELE
Amana LE8457L2 DRYER- ELE
Amana LE8457W DRYER- ELE
Amana LE8457W2 DRYER- ELE
Amana LE8467L2 DRYER- ELE
Amana LE8467W2 DRYER- ELE
Amana LE8507W DRYER- ELE
Amana LE8517L2 DRYER- ELE
Amana LE8517W2 DRYER- ELE
Amana LE8517W2B DRYER- ELE
Amana LE8567L2 DRYER- ELE
Amana LE8567W2 DRYER- ELE
Whirlpool LE8600XWW0 Residential Dryer
Amana LE8607L2 DRYER- ELE
Amana LE8607W DRYER- ELE
Amana LE8607W2 DRYER- ELE
Whirlpool LE8650XWW0 Residential Dryer
Whirlpool LE8860XWQ0 Residential Dryer
Amana LE9002 WASHER-TOP LOADING
Amana LE9002 DRYER- ELE
Amana LE9012 WASHER-TOP LOADING
Whirlpool LE9100XTW0 Residential Dryer
Whirlpool LE9100XTW1 Residential Dryer
Amana LE9107W DRYER- ELE
Whirlpool LE9200XWW0 Residential Dryer
Whirlpool LE9200XWW1 Residential Dryer
Amana LE9207L2 DRYER- ELE
Amana LE9207W DRYER- ELE
Amana LE9207W2 DRYER- ELE
Whirlpool LE9300XTW0 Residential Dryer
Whirlpool LE9300XTW1 Residential Dryer
Whirlpool LE9380XTW0 Residential Dryer
Whirlpool LE9480XWW0 Residential Dryer
Whirlpool LE9480XWW1 Residential Dryer
Whirlpool LE9500XTF0 ELECTRIC DRYER
Whirlpool LE9500XTG0 ELECTRIC DRYER
Whirlpool LE9500XTM0 ELECTRIC DRYER
Whirlpool LE9500XTN0 ELECTRIC DRYER
Whirlpool LE9500XTW0 Residential Dryer
Whirlpool LE9500XTW1 Residential Dryer
Whirlpool LE9520XTW0 Residential Dryer
Whirlpool LE9520XTW1 Residential Dryer
Whirlpool LE9680XWW0 Residential Dryer
Whirlpool LE9680XWW1 Residential Dryer
Whirlpool LE9800XMW0 Residential Dryer
Whirlpool LE9800XMW1 Residential Dryer
Whirlpool LE9800XMW2 Residential Dryer
Whirlpool LE9800XPF1 ELECTRIC DRYER
Whirlpool LE9800XPG1 ELECTRIC DRYER
Whirlpool LE9800XPM1 ELECTRIC DRYER
Whirlpool LE9800XPN1 ELECTRIC DRYER
Whirlpool LE9800XPT1 ELECTRIC DRYER
Whirlpool LE9800XPW0 Residential Dryer
Whirlpool LE9800XPW1 ELECTRIC DRYER
Whirlpool LE9800XSN0 ELECTRIC DRYER
Whirlpool LE9800XSW0 Residential Dryer
Whirlpool LE9805XPW0 Residential Dryer
Amana LEA10AW DRYER- ELE
Amana LEA20AL DRYER- ELE
Amana LEA20AW DRYER- ELE
Amana LEA30AL DRYER- ELE
Amana LEA30AW DRYER- ELE
Amana LEA50AL DRYER- ELE
Amana LEA50AW DRYER- ELE
Amana LEA60AL DRYER- ELE
Amana LEA60AW DRYER- ELE
Amana LEA80AL DRYER- ELE
Amana LEA80AW DRYER- ELE
Amana LEA90AL DRYER- ELE
Amana LEA90AW DRYER- ELE
General Electric LEB116GR1AD Electric range
General Electric LEB116GR1WH Electric range
General Electric LEB116GT1AD Electric range
General Electric LEB116GT1WH Electric range
General Electric LEB116GT2AD Electric range
General Electric LEB116GT2WH Electric range
General Electric LEB131GR1AD Electric range
General Electric LEB131GR1WH Electric range
General Electric LEB131GT1AD Electric range
General Electric LEB131GT1WH Electric range
General Electric LEB131GT2AD Electric range
General Electric LEB131GT2WH Electric range
General Electric LEB131GY1AD Electric range
General Electric LEB131GY1WH Electric range
General Electric LEB131GY2AD Electric range
General Electric LEB131GY2WH Electric range
General Electric LEB133GS1WW Electric range
General Electric LEB316GR1AD Electric range
General Electric LEB316GR1WH Electric range
General Electric LEB316GT1AD Electric range
General Electric LEB316GT1WH Electric range
General Electric LEB316GT2AD Electric range
General Electric LEB316GT2WH Electric range
General Electric LEB316GT3AD Electric range
General Electric LEB316GT3WH Electric range
General Electric LEB316GT4AD Electric range
General Electric LEB316GT4WH Electric range
General Electric LEB316GT5AD Electric range
General Electric LEB316GT5WH Electric range
General Electric LEB326GR1AD Electric range
General Electric LEB326GR1WH Electric range
General Electric LEB326GT1AD Electric range
General Electric LEB326GT1WH Electric range
General Electric LEB326GT2AD Electric range
General Electric LEB326GT2WH Electric range
General Electric LEB326GT3AD Electric range
General Electric LEB326GT3WH Electric range
General Electric LEB326GT4AD Electric range
General Electric LEB326GT4WH Electric range
General Electric LEB326GT5AD Electric range
General Electric LEB326GT5WH Electric range
General Electric LEB327GS1WW Electric range
General Electric LEB327GT1WW Electric range
  #2 (permalink)
Old 01-17-2010, 07:26 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
According to the service manual, you should get zero ohm reading (that should be a heater on the thermostat that allows for lower dryer temps) but you really need a wiring diagram to be certain. For some reason the wiring diagrams in the service manual are blank, (see below)
http://www.servicematters.com/maytag.../RS3200001.pdf
so see if you have one on the back or under the console.
__________________
  #3 (permalink)
Old 01-17-2010, 07:56 AM
Junior Member
Default
i really appreciate the comeback sidfink43.....it does not help tho..i went through the manual you refered to..it's the same as others i've looked at and does not tell me what i need to know..i'm wondering if i can bypass the fabric select switch(temp control) and wire it direct..i only need hot air not fluff or low heat...any idea's?
  #4 (permalink)
Old 01-17-2010, 09:26 AM
Senior Expert
APP Volunteer
Default
The short answer to your question is no. Actually the long answer is the same.
A dryer involves high voltage, high amperage and high heat. It is just not something you want to re-engineer as much as it might seem to be an easy and no-risk proposition.
For electrical problems if a wiring diagram is not available I will trace out the wiring, and if I still cannot find the problem I will replace the relevant parts and put in new wiring if I think that is the problem. I would never do a by-pass on my machine at home, and I don't think you should also.
Good luck
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Checking thermostat in Whirlpool oven Jay Schad Oven Repair (including Ranges and Cooktops) 4 03-07-2010 05:15 PM
Dryer too hot - how to test 4-prong thermostat? aliensoup Dryer Repair 4 01-29-2010 01:42 AM
amana no heat...checking 3 prong thermostat blu42nite Dryer Repair 1 01-17-2010 07:29 AM
Checking an amana Glow plug allen60089 Oven Repair (including Ranges and Cooktops) 0 11-07-2009 09:42 AM
Jenn-Air cartridge retro-fit 3 prong/4 prong vfxmark Oven Repair (including Ranges and Cooktops) 0 01-02-2008 09:32 AM
