Dwaine
#1 Posted : Friday, January 15, 2010 10:43:38 AM(UTC)
Dwaine
I have a Whirlpool dryer. Dried 2 loads this morning and went to start another load and when I set the timer. You could hear it ticking but when I pushed the start button, it would click but not start. Do I need to replace the start button or something else?
#2 Posted : Friday, January 15, 2010 12:36:27 PM(UTC)
Hi Dwaine,
The first thing I would do is check for continuity the thermal fuse (#59 on the diagram). If this fuse is open, it has to be replaced together with the cycling thermostat (#42), and the vent line has to be cleaned.
- The thermal fuse Part number: AP3133489
- The cycling thermostat Part number: AP3045874
Dan V.
#3 Posted : Sunday, April 25, 2010 3:16:09 PM(UTC)
Dan V.
Hi Gene,
I have the same model dryer and just discovered that the drum spins but has no heat. I'm trying to check continuity of the thermal fuse, but I can't figure out how to remove the back of the dryer to get at it. Any suggestions?
TIA,
Dan V.
Dan V.
#4 Posted : Sunday, April 25, 2010 3:31:32 PM(UTC)
Dan V.
Actually, now that I'm looking closer at it, I think the back panel is non-removable. Not sure at this point how to go about checking thermal fuse continuity.
#5 Posted : Monday, April 26, 2010 1:09:57 PM(UTC)
You have to remove the toe panel (#61 on the diagram) and the lint screen housing (#45 on the diagram). The thermal fuse is shown as #59.
Dan V.
#6 Posted : Monday, April 26, 2010 1:21:11 PM(UTC)
Dan V.
Gene,
Thanks for the reply. I've already determined that the fuse is not the issue. I tested that, the thermal cut off and high-limit thermostat and all checked out. The heating element was not testing well on my meter, so I pulled the canister and slid it out. It turns out the heating element has a broken wire. I ordered the new part from APP today.
As soon as it arrives, I'll install it and post back with the result.
Dan V.
#7 Posted : Tuesday, April 27, 2010 7:38:54 AM(UTC)
Dan V.
You guys are awesome! My new element arrived this morning. Overnight, even though I paid for standard ground shipping. Took me about 10 minutes to install and now all is well!
Thanks again for being here!
Dan V.
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
Whirlpool dryer---need to hold start button several seconds (Dryer Repair)
by pjlarivi 2/13/2021 10:44:25 AM(UTC)
