Discuss
Dryer won't stay running.
 in
Dryer Repair
I turn the dryer on and it makes about 1 turn and then shuts off Please HELP!. Ads By Google
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't stay running.
  #1 (permalink)
Old 01-13-2010, 03:21 PM
Junior Member
nwpop05 is on a distinguished road
Default Dryer won't stay running.
Model Number: 417.91702000   Brand: Kenmore   Age: 5 - 10 years
Please HELP!.
Ads By Google
Related Models
Kenmore 417.91702000  LAUNDRY CENTER
Kenmore 417.91702001  LAUNDRY CENTER
Kenmore 417.92042100  DRYER
Kenmore 417.92042101  DRYER
Kenmore 417.92042102  SEARS/GAS DRYER
Kenmore 417.92052101  DRYER
Kenmore 417.92052102  DRYER
Kenmore 417.92052103  SEARS/GAS DRYER
Kenmore 417.92142100  DRYER
Kenmore 417.92142101  DRYER
Kenmore 417.92142102  SEARS/GAS DRYER
Kenmore 417.92702200  LAUNDRY CENTER
Kenmore 417.93042200  SEARS/DRYER
Kenmore 417.93042201  SEARS/DRYER
Kenmore 417.93052200  SEARS/DRYER
Kenmore 417.93052201  SEARS/DRYER
Kenmore 417.93142200  SEARS/DRYER
Kenmore 417.93142201  SEARS/DRYER
Kenmore 417.93702200  LAUNDRY CENTER
Kenmore 417.93802200  LAUNDRY CENTER
Frigidaire 41739012890 Frg(v0) / Washer
Frigidaire 41739012891
Frigidaire 41739022890 Frg(v0) / Washer
Frigidaire 41739022891 Frg/washer
Frigidaire 41749012890 Frg(v0) / Dryer
Frigidaire 41749022890 Frg(v0) / Dryer
Frigidaire 41759012890 Frg(v0) / Dryer
Frigidaire 41759022890 Frg(v0) / Dryer
Kenmore 41784988100 AUTOMATIC WASHER
Kenmore 41784988800 AUTOMATIC WASHER
Kenmore 41789190100 COMBINATION WASHER/DRYER
Kenmore 41789190110 COMBINATION WASHER/DRYER
Kenmore 41789190120 COMBINATION WASHER/DRYER
Kenmore 41789190600 COMBINATION WASHER/DRYER
Kenmore 41789190610 COMBINATION WASHER/DRYER
Kenmore 41789190620 COMBINATION WASHER/DRYER
Kenmore 41789190800 COMBINATION WASHER/DRYER
Kenmore 41789190810 COMBINATION WASHER/DRYER
Kenmore 41789190820 COMBINATION WASHER/DRYER
Kenmore 41789195100 COMBINATION WASHER/DRYER
Kenmore 41789195110 COMBINATION WASHER/DRYER
Kenmore 41789195120 COMBINATION WASHER/DRYER
Kenmore 41789195600 COMBINATION WASHER/DRYER
Kenmore 41789195610 COMBINATION WASHER/DRYER
Kenmore 41789195620 COMBINATION WASHER/DRYER
Kenmore 41789195800 COMBINATION WASHER/DRYER
Kenmore 41789195810 COMBINATION WASHER/DRYER
Kenmore 41789195820 COMBINATION WASHER/DRYER
Kenmore 41789390100 COMBINATION WASHER/DRYER
Kenmore 41789390101 COMB, WASHER/DRYER
Kenmore 41789390110 COMBINATION WASHER/DRYER
Kenmore 41789390600 COMBINATION WASHER/DRYER
Kenmore 41789390700 COMBINATION WASHER/DRYER
Kenmore 41789390701 COMB, WASHER/DRYER
Kenmore 41789390710 COMBINATION WASHER/DRYER
Kenmore 41789390800 COMBINATION WASHER/DRYER
Kenmore 41789390801 COMB, WASHER/DRYER
Kenmore 41789390810 COMBINATION WASHER/DRYER
Kenmore 41789395100 WASHER-DRYER
Kenmore 41789395101 COMBINATION WASHER/DRYER
Kenmore 41789395110 COMBINATION WASHER/DRYER
Kenmore 41789395600 WASHER-DRYER
Kenmore 41789395701 COMBINATION WASHER/DRYER
Kenmore 41789395710 COMBINATION WASHER/DRYER
Kenmore 41789395800 WASHER-DRYER
Kenmore 41789395801 COMBINATION WASHER/DRYER
Kenmore 41793042202 DRYER
Kenmore 41793052202 DRYER
Kenmore 41793142202 DRYER
Kenmore 41793702201 SEARS/LAUNDRY CENTER
Kenmore 41793802201 LAUNDRY CENTER
Kenmore 41793812200 LAUNDRY CENTER
Kenmore 41793812201 LAUNDRY CENTER
Kenmore 41793814200 LAUNDRY CENTER
Kenmore 41793814201 LAUNDRY CENTER
Kenmore 41793862200 LAUNDRY CENTER
Kenmore 41793862201 LAUNDRY CENTER
Kenmore 41793872200 LAUNDRY CENTER
Kenmore 41793872201 LAUNDRY CENTER
Kenmore 41794802300 LAUNDRY CENTER
Kenmore 41794802301 LAUNDRY CENTER
Kenmore 41794812300 LAUNDRY CENTER
Kenmore 41794812301 LAUNDRY CENTER
Kenmore 41794814300 LAUNDRY CENTER
Kenmore 41794814301 LAUNDRY CENTER
Kenmore 41794862300 LAUNDRY CENTER
Kenmore 41794862301 SEARS/LAUNDRY CENTER
Kenmore 41794872300 LAUNDRY CENTER
Kenmore 41794872301 SEARS/LAUNDRY CENTER
Kenmore 41794988101 AUTOMATIC WASHER
Kenmore 41794988110 AUTOMATIC WASHER
Kenmore 41794988801 AUTOMATIC WASHER
Kenmore 41794988810 AUTOMATIC WASHER
Kenmore 41797802790 LAUNDRY CENTER
Kenmore 41797802791 WASHER/DRYER
Kenmore 41797802792 LAUNDRY CENTER
Kenmore 41797804790 LAUNDRY CENTER
Kenmore 41797804791 WASHER/DRYER
Kenmore 41797804792 LAUNDRY CENTER
Kenmore 41797862790 LAUNDRY CENTER
Kenmore 41797862791 WASHER/DRYER GAS LAUNDRY CENTER
Kenmore 41797862792 LAUNDRY CENTER
Kenmore 41797864790 LAUNDRY CENTER
Kenmore 41797864791 WASHER/DRYER
Kenmore 41797864792 LAUNDRY CENTER
Kenmore 41798702890 LAUNDRY CENTER
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
  #2 (permalink)
Old 01-14-2010, 03:35 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for KENMORE 417.91702000 | AppliancePartsPros.com
The 417 indicates that this is a Frigidaire unit.
The parts looks like it is a stacked unit, I could not cross reference it any further than that.
Following is a manual for a Frigidaire stacked unit but is a total guess on my part as to a match. It will at least give you some info on how Frigidaire does things if nothing else.
http://frigidaireservicetips.com/pdf...tionWasher.pdf
I turn the dryer on and it makes about 1 turn and then shuts off.
Can you restart it right away or do you have to wait a couple minutes?
If you have to wait this is often the dryer motor overheating and tripping it's internal thermal protect (cut-off). Though it does seem awful fast for an overheat condition.
Try turning the drum by hand in the correct direction to check if it is jamming up for some reason, should turn fairly easily.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Won't Stay Running MONA SMITH Dryer Repair 1 11-16-2009 05:28 AM
dryer won't stay running buzlong Dryer Repair 0 11-14-2009 03:57 PM
Dryer won't stay running Fixitchick Dryer Repair 3 09-24-2009 09:22 PM
G.E. gas dryer will not stay running skonny Dryer Repair 0 09-17-2009 07:12 AM
dryer won't stay running teetwofalcon Dryer Repair 1 08-08-2009 09:13 AM
