Discuss
scorched resistors
 in
Dryer Repair
Got the dreaded 8.8.... unplugged overnight then reconnected, mashed the start button and it tuned over, stopped, and 8.8. returned.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » scorched resistors
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-12-2010, 06:48 AM
Junior Member
scottsaunders is on a distinguished road
Default scorched resistors
Model Number: MDE5500AYW   Brand: Maytag   Age: 5 - 10 years
Got the dreaded 8.8.... unplugged overnight then reconnected, mashed the start button and it tuned over, stopped, and 8.8. returned. Pulled the board and the four 820 resistors in the UR corner are scorched-looking. Assuming that maybe just some condensation might have caused a short since the unit is in a semi-heated area and its bee very cold here but w/high humidity and that a quick board swap will do the trick but need to somehow confirm so as not to blow up another board. Comments?
Related Models
Maytag MDE5500AYW DRYER- ELE
Maytag MDE5500AZQ DRYER- ELE
Maytag MDE5500AZW DRYER- ELE
Maytag MDE5806AYK DRYER- ELE
Maytag MDE5806AYW DRYER- ELE
Maytag MDE5806AZK DRYER- ELE
Maytag MDE5806AZW DRYER- ELE
Maytag MDE5960AYW DRYER- ELE
Maytag MDE6000AUW DRYER- ELE
Maytag MDE6000AYQ DRYER- ELE
Maytag MDE6000AYW DRYER- ELE
Maytag MDE6000AZQ DRYER- ELE
Maytag MDE6000AZW DRYER- ELE
Maytag MDE6200AYQ DRYER- ELE
Maytag MDE6200AYW DRYER- ELE
Maytag MDE6200AZQ DRYER- ELE
Maytag MDE6200AZW DRYER- ELE
Maytag MDE6400AGW DRYER- ELE
Maytag MDE6400AYQ DRYER- ELE
Maytag MDE6400AYW DRYER- ELE
Maytag MDE6400AZW DRYER- ELE
Maytag MDE6460AYW DRYER- ELE
Maytag MDE6460AZW DRYER- ELE
Maytag MDE6657BYQ DRYER- ELE
Maytag MDE6657BYW DRYER- ELE
Maytag MDE6700AYW DRYER- ELE
Maytag MDE6700AZW DRYER- ELE
Maytag MDE6800AYQ DRYER- ELE
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
  #2 (permalink)
Old 01-13-2010, 01:38 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for MAYTAG MDE5500AYW Dryer - Ele | AppliancePartsPros.com
Cannot be very helpful but can at least supply you with some info.
http://www.servicematters.com/maytag...s/16023110.pdf
Try running the diagnostics.
I do not have a schematic for the board but you could try tracing back the resistors and then check that component.
The discoloration may be normal, I do not know. Hopefully someone with more experience will jump in and help out.
8 looks like a keypad problem. Check it with a meter.
You could try the following but it is a long shot as the error is a stuck key not an open key.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
  #3 (permalink)
Old 01-13-2010, 02:36 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
I would check the heater relay AP4037260. I have seen these short out before, but not on this model. Also, I use a non-residue contact cleaner available at Radio Shack.
__________________
  #4 (permalink)
Old 01-13-2010, 07:30 AM
Junior Member
Default scottsaunders
ok.
rad the pad check and came up w/some screwy stuff:
-pins 10 + 13 DNF
-pins 9+13 are the "time +"
-pins 12 + 14 DNF
-there is no pin #19 for the "damp dry"so thinking it might be #16 instead, tried it, DNF
-pins 11 + 15 are actually the "prevent" instead of "release" but do sem to operate "release" a bit....
The rest tested out ok
I metered the 820 resistors and they all check out +_ 5%
I notice that the top of the 16v cap is pooched up a bit and the hot melt is no longer attached to the board.
How do I check the Heater Relay?
  #5 (permalink)
Old 01-13-2010, 08:05 AM
Senior Expert
APP Volunteer
Default
If your capacitor is bulged out, your board is probably bad, an ac short to the capacitor will make it boil out liquids.
The relay I saw had shorted 230 volts to the coil and blew out the pc board. Just check the coil resistance.
__________________
  #6 (permalink)
Old 01-13-2010, 08:47 AM
Junior Member
Default
I see....
You mean the heater coil?
Could condensation have caused the AC short somewhere? Its been very cold here in NW Ga but with 77% + humidity and the unit is out in the "summer kitchen". The windows there have been so full of condensate that sash is getting moldy...
  #7 (permalink)
Old 01-13-2010, 02:23 PM
Senior Expert
APP Volunteer
Default
No,I am saying the little coil inside the heater relay may have arcted over to the 230 volt contacts. If so, the coil inside the plastic cover of the relay may be blown open, just check.
__________________
  #8 (permalink)
Old 01-13-2010, 03:30 PM
Junior Member
Default
Neither of the relays show any visible damage.
I have an older RatShack digital multimeter. Can I use it to check the cap and the relays?
  #9 (permalink)
Old 01-14-2010, 01:23 AM
Senior Expert
APP Volunteer
Default
You can check the relay coil but not the cap. There is evidence the cap vented steam so your board is bad and the relay suspect.
__________________
  #10 (permalink)
Old 01-14-2010, 03:15 AM
Senior Expert
APP Volunteer
Default
-pins 10 + 13 DNF
-pins 12 + 14 DNF
Ya lost me
What is DNF?
As richappy said your bulged capacitor does indicate that the board is toast.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven scorched cupboards during self clean cycle mimmonk Oven Repair (including Ranges and Cooktops) 0 01-16-2010 10:13 AM
Burnt Resistors on Control Board h2homem Dryer Repair 6 09-21-2009 04:52 PM
Burnt or scorched clothes smell livz2hunt Dryer Repair 1 07-10-2009 03:37 PM
Scorched clothing carla67 Dryer Repair 2 09-09-2008 08:12 AM
dryer has a scorched look on back panel john49 Dryer Repair 2 01-28-2008 04:31 PM
