| » Temperature selector switch |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Brand: Kenmore Age: 5 - 10 years
Is there a better way to check the temperature control selector switch when it is out of the circuit. I suspect the switch is bad, but I get irratic readings when I make continuity checks with a DVM. I had to replace the thermal switch, but the dryer still won't start.
I replaced the temperature selector switch and when I tried to start the dryer, it buzzed a couple of seconds then quit. I did smell something burning. I checked the resistors on the plug (two violet wires) and the're ok. I'm beginning to think the motor might be the problem. Any other suggestions before I go to all the trouble to check the motor windings?
| Display Modes | |
| selector knob replacement | napaynz | Dryer Repair | 1 | 03-06-2008 12:38 PM |
| GE Oven temperature | fivermillions | Oven Repair (including Ranges and Cooktops) | 1 | 12-25-2007 12:57 PM |
| oven temperature | rodrbrown | Oven Repair (including Ranges and Cooktops) | 0 | 12-08-2007 12:47 PM |
| infinite switch wiring change from 6 wires to 5 wire switch | wiedemanndds | Oven Repair (including Ranges and Cooktops) | 3 | 12-06-2007 12:45 PM |
| Infinite switch and fan switch | johnro24 | Oven Repair (including Ranges and Cooktops) | 0 | 12-05-2007 09:01 PM |
