I recently got a used Maytag Atlantis Gas Dryer (sorry don't have model number readily available). Anyway, it appears that the unit does not get very hot even though I have it set at teh higest setting. This model has the Intelli-dry system that determines moisture in the clothes. Since this is my first experience with this type of unit, my question is: Is this normal or does my unit need repairs? It ultimately drys the clothes, but it seems to take much longer than I am accustomed to with older units that seem to run really hot in the high setting. Please advise if you have had this problem or are familiar with this type of dryer. Thanks.
