Discuss
Gas Dryer fires one time only
 in
Dryer Repair
I have a Kenmore gas dryer which has worked fine for many years. Recently it stopped drying. I removed the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer fires one time only
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-30-2008, 07:31 PM
colsen colsen is offline
Junior Member
colsen is on a distinguished road
Default Gas Dryer fires one time only
Brand: Kenmore   Age: More than 10 years
I have a Kenmore gas dryer which has worked fine for many years. Recently it stopped drying. I removed the front panel and observed the burner. From a cold start it works fine - igniter glows, gas fires and runs for a few minutes. When gas cuts off the first time it will not restart - igniter glows then stops but no gas - this repeats every few minutes. Is this somehow related to the different funtion of the two soleniods?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-31-2008, 07:37 AM
fixtec90 fixtec90 is offline
Senior Expert
APP Volunteer
fixtec90 is on a distinguished road
Default
Yes it does relate to the coils (soleniods) The primary allows juice to the ignitor and the secondary allows gas to flow. Replace both.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lint alarm sounds after approx 3 min run time creating a rift in the space time conti beachygreen Dryer Repair 0 03-11-2008 07:06 AM
Gas dryer fires gas only once = igniter works AOK Gary Houda Dryer Repair 14 02-22-2008 07:36 PM
Dryer does not start all the time??? gthoman Dryer Repair 15 01-23-2008 09:28 AM
ignitor fires continuously a92780 Oven Repair (including Ranges and Cooktops) 1 10-06-2007 08:04 AM
Dryer only fires once Thomas C Dryer Repair 0 09-25-2007 10:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
