Discuss
motor shaft play
 in
Dryer Repair
The impeller attached to the motor (#AP2043550) is now rubbing on the steel cover in the front lower lefthand corner
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » motor shaft play
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-30-2008, 07:22 PM
plubbers plubbers is offline
Junior Member
plubbers is on a distinguished road
Default motor shaft play
Model Number: DPSF495GV0WW   Brand: GE   Age: 5 - 10 years
The impeller attached to the motor (#AP2043550) is now rubbing on the steel cover in the front lower lefthand corner of the dryer.The motor seems to be ok, but the shaft has about 1/4 inch of play from front to back. Would the motor have to be replaced?
I am going to replace the 4 drum slides and rear drum bearing kit.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-01-2008, 01:02 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Quote:
Originally Posted by plubbers View Post
...The impeller attached to the motor (#AP2043550) is now rubbing on the steel cover in the front lower lefthand corner of the dryer.The motor seems to be ok, but the shaft has about 1/4 inch of play from front to back. Would the motor have to be replaced?...
I'm afraid I did not get you right. When you said "impeller", which part did you mean:
The motor pulley
or
The blower wheel
If we are talking about the motor pulley, it has a screw which could be tighten.
If we are talking about the blower wheel - it also has a screw which could be tighten and if it would not help then it has to be replaced.
The motor shaft should not play and if it does - the motor has to be replaced.
- The part number for the motor (including the motor pulley) is AP2043550
- The part number for the blower wheel is AP2043548
Here are the break down diagrams for the GE dryer Model DPSF495GV0WW
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burner knob/shaft feels broken on cooktop jeffthx Oven Repair (including Ranges and Cooktops) 1 03-10-2008 10:14 AM
Agitator & Shaft came out of transmission ddavis98 Washer Repair 0 02-03-2008 07:39 AM
Shaft Seal instalation 4704 Washer Repair 1 12-12-2007 11:39 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
