Discuss
Maytag Dryer - Wrinkle Prevent timer
 in
Dryer Repair
Hi, I just purchased a Maytag Centennial MED5820TW0 dryer from Sears. The timer has two "Wrinkle Prevent" cycles
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer - Wrinkle Prevent timer
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-29-2008, 08:41 AM
sled351 sled351 is offline
Junior Member
sled351 is on a distinguished road
Default Maytag Dryer - Wrinkle Prevent timer
Model Number: MED5820TW0   Brand: Maytag   Age: Less than 1 year
The timer has two "Wrinkle Prevent" cycles on it, a 30-minute cycle, and a 90-minute cycle, which periodically tumble the drum after the Auto-Dry cycle has completed. It also has a 3-position switch on the console for "Wrinkle-Prevent" OFF, 30min, and 90min.
After running through the Auto Dry cycle, the timer motor continues to run into the "Wrinkle Prevent" cycle even if the "wrinkle prevent" switch on the front panel is set to OFF. The timer motor seems to stop after the 30 minute wrinkle prevent if the 3-position switch is set to OFF or 30 Min.
Is this normal behavior? Or do I need to call the service tech?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-29-2008, 12:33 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Quote:
Originally Posted by sled351 View Post
....After running through the Auto Dry cycle, the timer motor continues to run into the "Wrinkle Prevent" cycle even if the "wrinkle prevent" switch on the front panel is set to OFF. The timer motor seems to stop after the 30 minute wrinkle prevent if the 3-position switch is set to OFF or 30 Min.
Does it tumble at this time?
If it does when the switch is "off" - this is not normal and you have to call Sears.
If it does not - don't worry about it.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 03-30-2008, 04:32 AM
Junior Member
Default
No, only the timer motor runs. However, the boss doesn't like it and she wants it fixed. My concern is that they'll come out, replace the timer, and it will do the same thing. My question is, "is that normal?" If it is, maybe I can convince the boss.
  #4 (permalink)
Old 04-01-2008, 09:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I can not tell you exactly because I do not have the tech sheets for this model.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dryer Timer Install ski9826 Dryer Repair 1 03-27-2008 07:26 PM
How to replace Maytag Dryer timer switch? tlhjax Dryer Repair 1 03-11-2008 05:12 PM
coin op dryer timer starts but dryer doesn't turn on Mike Craw Dryer Repair 4 01-10-2008 07:26 PM
Maytag Dryer timer won't turn off dugclark Dryer Repair 3 10-22-2007 02:15 AM
Maytag - Dryer not heating timer mode freebird Dryer Repair 0 08-16-2007 11:06 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
