| » Electric dryer makes the end of cycle sound when i push the start button |
A Make and Model Number may help others help you.
If it is the end of cycle buzzer it could be a timer problem. May also be that the buzzing is coming from the motor trying to start. The following will probably require two people. Set the unit to air fluff. As running a unit with the door open can cause overheating blowing a thermal fuse. Check it to see if it still does not start. If it does not start. Open the door and push the door switch so the unit thinks the door is closed. Push the start switch and while it is buzzing rotate the dryer drum in the correct direction. Watch you knuckles in case the unit starts up. If it does start then you have a motor problem.
__________________
| Display Modes | |
| whirlpol dryer won't start-just hums when I push the start button | bdubois | Dryer Repair | 27 | 02-18-2010 07:36 PM |
| Dryer has humming noise when start button is push | jgaines | Dryer Repair | 1 | 06-21-2009 03:53 PM |
| Kenmore Dryer won't start unless PTS (push to start) button depressed and held | trp | Dryer Repair | 1 | 06-07-2009 06:13 AM |
| gas dryer will not work but makes sound when you press the start button | cdhawkinsiii | Dryer Repair | 1 | 01-12-2009 05:43 AM |
| Washer Makes Strange Noise When I Push Start Button | Kelli Huntsman | Washer Repair | 0 | 01-05-2009 09:28 AM |
