Discuss
Dryer won't heat and runs non stop.
 in
Dryer Repair
My electric dryer quit heating and actually ran all night without stopping. Do I need to replace the heating element
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't heat and runs non stop.
  #1 (permalink)
Old 01-06-2010, 12:15 PM
Junior Member
Paul LeGrande is on a distinguished road
Question Dryer won't heat and runs non stop.
Model Number: LER4634PQO   Brand: Whirlpool   Age: 1 - 5 years
My electric dryer quit heating and actually ran all night without stopping. Do I need to replace the heating element or is it just a Fuse?
Related Models
Whirlpool LER4634PT0 29" ELECTRIC DRYER
Whirlpool LER4634PT1 29" ELECTRIC DRYER
Whirlpool LER5434AW0 Residential Dryer
Whirlpool LER5600HQ0 ELECTRIC DRYER
Whirlpool LER5600HZ0 ELECTRIC DRYER
Whirlpool LER5600JQ0 ELECTRIC DRYER
Whirlpool LER5600JT0 ELECTRIC DRYER
Whirlpool LER5620KQ0 RESIDENTIAL DRYER
Whirlpool LER5620KQ1 ELECTRIC DRYER
Whirlpool LER5620KQ2 29"ELECTRIC DRYER
Whirlpool LER5624BN0 ELECTRIC DRYER
Whirlpool LER5624BN1 ELECTRIC DRYER
Whirlpool LER5624BN2 ELECTRIC DRYER
Whirlpool LER5624BW0 ELECTRIC DRYER
Whirlpool LER5624BW1 ELECTRIC DRYER
Whirlpool LER5624BW2 ELECTRIC DRYER
Whirlpool LER5624DQ0 DRYERS
Whirlpool LER5624DQ1 ELECTRIC DRYER
Whirlpool LER5624DW1 ELECTRIC DRYER
Whirlpool LER5624DZ0 DRYERS
Whirlpool LER5624DZ1 ELECTRIC DRYER
Whirlpool LER5634AN0 ELECTRIC DRYERS
Whirlpool LER5634AQ0 ELECTRIC DRYER
Whirlpool LER5634AQ1 ELECTRIC DRYER
Whirlpool LER5634AQ2 ELECTRIC DRYER
Whirlpool LER5634AW0 ELECTRIC DRYERS
Whirlpool LER5634DQ1 DRYER
Whirlpool LER5634EQ0 ELECTRIC DRYER
Whirlpool LER5634EZ0 ELECTRIC DRYER
Whirlpool LER5634LG0 RESIDENTIAL DRYER
Whirlpool LER5634LQ0 29" ELECTRIC DRYER
Whirlpool LER5634LT0 RESIDENTIAL DRYER
Whirlpool LER5634LW0 RESIDENTIAL DRYER
Whirlpool LER5635LQ0 29"ELECTRIC DRYER
Whirlpool LER5635LQ1 29"ELECTRIC DRYER
Whirlpool LER5636DW0 ELECTRIC DRYER
Whirlpool LER5636DW1 ELECTRIC DRYER
Whirlpool LER5636EQ0 ELECTRIC DRYER
Whirlpool LER5636EQ1 ELECTRIC DRYER
Whirlpool LER5636EQ2 ELECTRIC DRYER
Whirlpool LER5636EQ3 ELECTRIC DRYER
Whirlpool LER5636EZ0 ELECTRIC DRYER
Whirlpool LER5636EZ01 ELECTRIC DRYER
Whirlpool LER5636EZ1 DRYER
Whirlpool LER5636EZ2 ELECTRIC DRYER
Whirlpool LER5636EZ3 ELECTRIC DRYER
Whirlpool LER5636JQ0 ELECTRIC DRYER
Whirlpool LER5636JT0 ELECTRIC DRYER
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
Whirlpool LER5638AN2 ELECTRIC DRYER
Whirlpool LER5638AN3 ELECTRIC DRYER
Whirlpool LER5638AW0 Residential Dryer
Whirlpool LER5638AW1 ELECTRIC DRYER
Whirlpool LER5638AW2 ELECTRIC DRYER
Whirlpool LER5638AW3 ELECTRIC DRYER
Whirlpool LER5644AN1
Whirlpool LER5644AN2 ELECTRIC DRYER
Whirlpool LER5644AW0 Residential Dryer
Whirlpool LER5644AW1
Whirlpool LER5644AW2 ELECTRIC DRYER
Whirlpool LER5644EQ0 ELECTRIC DRYER
Whirlpool LER5644EQ1 ELECTRIC DRYER
Whirlpool LER5644EQ2 ELECTRIC DRYER
Whirlpool LER5644EZ0 ELECTRIC DRYER
Whirlpool LER5644EZ1 ELECTRIC DRYER
Whirlpool LER5644EZ2 ELECTRIC DRYER
Whirlpool LER5644JQ0 DRYER
Whirlpool LER5644JQ1 DRYER
Whirlpool LER5644JQ2 RESIDENTIAL DRYER
Whirlpool LER5644JQ3 29"ELECTRIC DRYER
Whirlpool LER5644JT0 DRYER
Whirlpool LER5644JT1 DRYER
Whirlpool LER5644JT2 RESIDENTIAL DRYER
Whirlpool LER5644JT3 29"ELECTRIC DRYER
Whirlpool LER5644PQ0 29"ELECTRIC DRYER
Whirlpool LER5644PQ1 29"ELECTRIC DRYER
Whirlpool LER5700KQ0 RESIDENTIAL DRYER
Whirlpool LER5700KQ1 RESIDENTIAL DRYER
Whirlpool LER5700KT0 RESIDENTIAL DRYER
Whirlpool LER5700KT1 RESIDENTIAL DRYER
Whirlpool LER5848EQ0 ELECTRIC DRYER
Whirlpool LER5848EQ1 ELECTRIC DRYER
Whirlpool LER5848EQ2 ELECTRIC DRYER
Whirlpool LER5848EQ3 DRYERS
Whirlpool LER5848EQ4 DRYERS
Whirlpool LER5848EQ5 ELECTRIC DRYER
Whirlpool LER6611LQ0 RESIDENTIAL DRYER
Whirlpool LER6611LQ1 29"ELECTRIC DRYER
Whirlpool LER6611PQ0 29" ELECTRIC DRYER
Whirlpool LER6620PQ0 29"ELECTRIC DRYER
Whirlpool LER6620PQ1 29"ELECTRIC DRYER
Whirlpool LER6620PT0 29"ELECTRIC DRYER
Whirlpool LER6620PT1 29"ELECTRIC DRYER
Whirlpool LER6621PQ0 29" ELECTRIC DRYER
Whirlpool LER6634BN0 ELECTRIC DRYER
Whirlpool LER6634BN1 ELECTRIC DRYER
Whirlpool LER6634BN2 ELECTRIC DRYER
Whirlpool LER6634BQ0 ELECTRIC DRYER
Whirlpool LER6634BQ1 ELECTRIC DRYER
Whirlpool LER6634BQ2 ELECTRIC DRYER
Whirlpool LER6634BW0 ELECTRIC DRYER
Whirlpool LER6634BW1 ELECTRIC DRYER
Whirlpool LER6634BW2 ELECTRIC DRYER
Whirlpool LER6634DQ0 ELECTRIC DRYER
Whirlpool LER6634DQ1 ELECTRIC DRYER
Whirlpool LER6634DW0 ELECTRIC DRYER
  #2 (permalink)
Old 01-06-2010, 12:54 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for LER4634PQO models | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/w...%208528187.pdf
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the timer requires the full 240 volts.
If this does nothing then put the timer on Timed Dry mid cycle.
If the timer does not advance then you probably have a power problem somewhere
If the timer advances, you have the 240 volts.
Then the heater becomes the prime suspect.
When in an Auto mode the timer gets power through the heater when the thermostat shuts it off so if the heater blows the timer does not advance and it will run forever.
__________________
  #3 (permalink)
Old 03-12-2014, 02:21 PM
Junior Member
Elroy_Jetson is on a distinguished road
Thumbs up
Quote:
This right here solved my problem! I was googling how to fix my same exact dryer with the same exact problem. I checked the continuity of all the electrical components, replaced the heating element (which I didn't need to do), and cleaned out the vent -all to no avail. As per this youtube video right here: Fixing an Electric Dryer that Doesn't Heat and the Timer Won't Advance (but the motor runs) - YouTube I thought it might have something to do with the power. More googling had me stumble on your post.
I switched the breaker off and on a couple times and BOOM! It works. Thanks a bunch!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2 year old Whirlpool runs but no heat and wont stop on its own jriden37 Dryer Repair 1 11-13-2009 02:22 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Kenmore Dryer runs but won't stop Rick Day Dryer Repair 16 07-20-2008 01:03 PM
GE Gas Dryer-no heat, doesn't stop tenor_ringer Dryer Repair 1 11-26-2007 02:35 PM
Dryer wont stop cycle automatically runs continously MrSchlimmer Dryer Repair 1 10-31-2007 03:43 AM
