Discuss
drum out of line-staining clothes
 in
Dryer Repair
I am noticing black marks and some tiny holes on my clothes after dry cycle, where clothes appear to be
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » drum out of line-staining clothes
  #1 (permalink)
Old 03-27-2008, 02:08 PM
stepdance stepdance is offline
Junior Member
stepdance is on a distinguished road
Default drum out of line-staining clothes
Model Number: DE 212   Brand: Maytag   Age: More than 10 years
I am noticing black marks and some tiny holes on my clothes after dry cycle, where clothes appear to be caught on something inside dryer. I see a gap between rim on back of dryer. How do you re-align this?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-27-2008, 03:02 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Both the rear and the front tumbler seals have to be replaced.
In order to provide the right part number I need the color of the tumbler (gray or beige).
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 03-27-2008, 03:48 PM
Junior Member
Default
the inside of the dryer is grey, and I can see a matted felt through the gap. Thank you for answering!
  #4 (permalink)
Old 03-27-2008, 04:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The part number for the front and rear tumbler seals (they are the same) is AP286710
You also need to order the adhesive to attach them. The part number for the adhesive is AP3970861
Here are the break down diagrams for the Maytag dryer Model DE212
__________________
  #5 (permalink)
Old 03-30-2008, 09:36 PM
pamlthomas pamlthomas is offline
Junior Member
pamlthomas is on a distinguished road
Default
Gene,
I am having the same problem with my Sears 417.69052991 model dryer. My clothes are catching in the gap and getting discolored and stretched out of shape. The drum also is squeaking. Can you tell me what to do to correct this issue and what parts I need?
  #6 (permalink)
Old 04-01-2008, 10:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The same problem - the same solution.
You have to replace the front seal (there is no rear seal) which consists of two parts: the drum glide and the lower seal.
- The part number for the drum glide is AP2150497
- The part number for the lower seal is AP2143044
__________________
  #7 (permalink)
Old 05-04-2008, 11:18 AM
Fidobrad Fidobrad is offline
Junior Member
Fidobrad is on a distinguished road
Default Replaced Drums Seals, but Drum not turning....
Hello,
I replaced the felt seals in the front and rear of the dryer. The drum turned fine before my repair, but now it turns very, very slowly. Any suggestions? Also, when putting in the felt seal, should it overlap at a tab or in between to prevent binding? Thanks for your help!
  #8 (permalink)
Old 05-04-2008, 01:27 PM
Junior Member
Default More information on Dryer
The model number on my Maytag is LDE7304ACE. In addition to replacing the felt drum seals, I replaced the drum wheels - one of which had fallen off the shaft. We used part no. 413820 - is this the rights seals for the front and back, but took them out when the drum was not turning and put in the old ones. Drum still won't turn though. Thanks for your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
u-line Bar Frig N Miller Refrigerator & Freezer Repair 2 03-30-2008 07:51 AM
U-line runs constantly wreckitnow Refrigerator & Freezer Repair 3 03-02-2008 02:55 PM
Clothes get stuck in drum above door mradke Dryer Repair 1 12-29-2007 02:27 PM
gas supply line jamiedunham Oven Repair (including Ranges and Cooktops) 0 11-27-2007 02:27 PM
Can't connect gas line caligal64 Oven Repair (including Ranges and Cooktops) 0 11-22-2007 10:16 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
