Dryer not heating.
I have checked the continuity of the Heating Element, Thermostat fixed, Thermal Fuse, Dryer Cycling Thermostat and the Thermostat Cutoff. The Thermostat Cutoff is the only one that is open. I have not check any of these with the power on at this point. Is my problem the Thermostat Cutoff or am I missing something?
Replace the thermal cut-off and the highl limit thermostat. I am also of the mind to say replace the cycling thermostat also.
That should do it.
Oh yes, thoroughly clean out the inside of the dryer including lint chute and the outside venting system.
