janekuz
#1 Posted : Saturday, January 2, 2010 6:41:11 PM(UTC)
janekuz
My dryer works fine but is makeing a terrible sqeeling noise. The clothes sometimes also get caught in the front top of the drum at the very top. Would it be the rear drum bearing? I don't mind fixing it as long as I can figure out the correct part to order.
#2 Posted : Sunday, January 3, 2010 2:43:46 AM(UTC)
Replacement parts for General Electric NVLR333ET0WB Electric dryer | AppliancePartsPros.com
You may have two problems.
You will have to open it up and check the rear support bearing and the front glides/support Item 454 in Section 2. lso check the belt and the idler roller.
Here is a good site that should be useful
http://www.applianceaid.com/dryers.html
janekuz
#3 Posted : Sunday, January 3, 2010 11:11:09 AM(UTC)
janekuz
Originally Posted by: denman Go to Quoted Post
Thanks Denman - In taking the dryer apart the whole entire top of the drum support is worn and cracked so I will replace that whole piece along with the 3 glides. All other parts look ok. I would have never thought to look there if you hadn't mentioned the front glides. Thanks again
