| » maytag dryer no heat |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: MDG7057BWQ Brand: Maytag Age: 1 - 5 years
opened front panel and no flame. Igniter not glowing.Checked coils ok.I am guessing maybe I need a igniter?
There are five major electrical parts involved in the heating process:
1. High limit thermostat (#17 on the gas valve break down diagram) 2. Cycling thermostat (#8 on the motor break down diagram) 3. Igniter (#4 on the gas valve break down diagram) 4. Flame sensor (#18 on the gas valve break down diagram) 5. Gas valve coils (#7 on the gas valve break down diagram) How to find out which part causing the problem? Pretty simple: all of these parts have to be tested for continuity in the above sequence. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter If any of them is open – it has to be replaced. Gas valve coils also could be tested by resistance. There are two coils – one with three terminals and one with two terminals. 1. Coil with two terminals should have 1220 ± 50 Ohms 2. Coil with three terminals if held with terminals in upper position: a) across the left and the middle terminals – 1365 ± 25 Ohms b) across the left and the right terminals – 560 ± 25 Ohms - The part number for the high limit thermostat is AP275754 - The part number for the cycling thermostat is AP276896 - The part number for the igniter is AP3109449 - The part number for the flame sensor is AP2910747 - The part number for the gas valve coils kit is AP3094251 Here are the break down diagrams for the Maytag dryer Model MDG7057BWQ Gene.
__________________
Professional appliance repair services in Orange County, California. |
Thanks Gene. I guess I really did not need to ask this question as you have answered it so many times in this forum.My igniter was cracked.This forum was a great help made changing this part a very simple process. Thanks again.
I'm glad you were able to fix it.
__________________
| Display Modes | |
| Maytag dryer - no heat | esh | Dryer Repair | 14 | 08-04-2008 08:43 PM |
| Maytag gas dryer with low heat | cmgonz | Dryer Repair | 2 | 03-24-2008 06:42 PM |
| Maytag dryer won't heat | raffi383 | Dryer Repair | 1 | 03-17-2008 06:09 PM |
| Maytag LSG7804AAE Dryer - Won't Heat Up | HockeyDave | Dryer Repair | 4 | 02-14-2008 12:37 PM |
| Help with Maytag Dryer-won't heat up | momto3 | Dryer Repair | 0 | 01-23-2008 08:54 AM |
