Discuss
Dryer Wont Heat And Found Green Cable Laying Inside Of Unit
 in
Dryer Repair
i bought a used dryer it worked at the house i bought it from but with all the moving, loading
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Wont Heat And Found Green Cable Laying Inside Of Unit
  #1 (permalink)
Old 12-31-2009, 10:10 AM
Junior Member
laurieallthumbs is on a distinguished road
Default Dryer Wont Heat And Found Green Cable Laying Inside Of Unit
Brand: Frigidaire   Age: 5 - 10 years
i bought a used dryer it worked at the house i bought it from but with all the moving, loading and unloading, it wont heat up. We flipped it on its side and noticed a green cable with silver connectors on each side laying in the base of the dryer. can someone please tell me where this cable could possibly connect to.
  #2 (permalink)
Old 01-01-2010, 06:15 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Please add a Model Number as that is the only way to get the info you need.
If it is available.
Also knowing the length of the wire may help someone identify it for you.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Ovene lower unit wont heat. dpo1464 Oven Repair (including Ranges and Cooktops) 0 01-24-2010 09:49 AM
Dryer Heat Unit Will Not Ignite MISTERFIXFIT Dryer Repair 0 12-01-2009 08:57 AM
Dryer Heat Unit Will Not Ignite MISTERFIXFIT Dryer Repair 0 12-01-2009 08:53 AM
tub wobbles and oil found inside machine on bottom plate b.gale Washer Repair 1 08-29-2009 05:14 AM
no heat from dryer unit stefanos Dryer Repair 1 05-15-2009 05:00 PM
