Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Dryer Wont Heat And Found Green Cable Laying Inside Of Unit (http://forum.appliancepartspros.com/dryer-repair/66056-dryer-wont-heat-found-green-cable-laying-inside-unit.html)
laurieallthumbs 12-31-2009 09:10 AM
i bought a used dryer it worked at the house i bought it from but with all the moving, loading and unloading, it wont heat up. We flipped it on its side and noticed a green cable with silver connectors on each side laying in the base of the dryer. can someone please tell me where this cable could possibly connect to.
denman 01-01-2010 05:15 AM
Please add a Model Number as that is the only way to get the info you need.
If it is available.
Also knowing the length of the wire may help someone identify it for you.
