chad bailey
#1 Posted : Tuesday, December 29, 2009 5:06:54 PM(UTC)
chad bailey
Hello I have a Roper dryer and I can hear the timer turning when there is power but nothing else works. The fuse has continuity and the switch on the front door is working properly. I spent about 1 hour on the phone with a guy from the appliance store and we are stuck. I replaced the motor and everything seems to have continuity. I wonder if the timer is bad and if anyone knows how to test one.
sidfink43
#2 Posted : Thursday, December 31, 2009 2:46:56 PM(UTC)
sidfink43
Did you check continuity on your push to start switch? Your model may have a broken belt switch, so check that also.
If everything is ok, and you are getting power to the timer than the timer is likely the problem but you are going to have to replace it to be sure. Before you do that take off the connection and clean it with contact cleaner, and reseat it making sure everything fits correctly.
Roper Dryer problems (Dryer Repair)
by b0001744 8/29/2008 9:38:02 AM(UTC)
