Discuss
Dryer Controls not working
 in
Dryer Repair
Reconfigured our laundry room. Reran electric with same amp wire- plugged in and now the controls do not work. Checked
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Controls not working
  #1 (permalink)
Old 12-27-2009, 02:22 PM
Junior Member
lpreber76 is on a distinguished road
Default Dryer Controls not working
Model Number: 110.85089401   Brand: Kenmore   Age: 1 - 5 years
Reconfigured our laundry room. Reran electric with same amp wire- plugged in and now the controls do not work. Checked all the wires and they are showing the correct amount of amps coming in- grounds are good too. The only thing that does work in the light on the inside of the dryer when you open the door. Checked that the light went off when door was shut-it does. Have no idea why now it doesnt work- it was fine before we relocated it. Any ideas on what to try would be greatly appreciated- we are pretty handy- and would rather give it a shot ourselves then fork out hundreds for sears to spend 5 minutes fixing it. ThanksLaurellyn & Ralph Reber
Ads By Google
Related Models
Kenmore 110.86015100  ELECTRIC DRYER
Kenmore 110.86015110  ELECTRIC DRYER
Kenmore 110.86015120  ELECTRIC DRYER
Kenmore 110.86030100  ELECTRIC DRYER
Kenmore 110.86030110  ELECTRIC DRYER
Kenmore 110.86030120  ELECTRIC DRYER
Kenmore 110.86070100  ELECTRIC DRYER
Kenmore 110.86070110  ELECTRIC DRYER
Kenmore 110.86405160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86405860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407140  ELECTRIC DRYER
Kenmore 110.86407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407840  ELECTRIC DRYER
Kenmore 110.86407860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.87405140  GAS DRYER
Kenmore 110.87405160  COMMERCIAL GAS DRYER
Kenmore 110.87405840  GAS DRYER
Kenmore 110.87405860  COMMERCIAL GAS DRYER
Kenmore 110.87407140  GAS DRYER
Kenmore 110.87407840  GAS DRYER
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
  #2 (permalink)
Old 12-28-2009, 01:10 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Look inside the lower access panel and see if you find some tech notes that may allow you to put it into a test/diagnosis mode.
I am assuming the unit is completely dead, no lights or anything.
On these models L1 power goes to the light and the control board, so it looks like your control board is getting power, but trace the wiring and make sure.
Normally if the control board is getting power but the machine will not run the control board is the problem, but see what diagnosis/tests will tell you and check out the L2 wiring to make sure you do not have a problem there.
__________________
  #3 (permalink)
Old 01-04-2010, 07:45 PM
Junior Member
Default Thanks for your help
Thanks for the information- we got the diagnostic paper out- and yes looks like its the control board. I was hoping it wasnt- but got one on ******** for 75 bucks- much less then what I had anticipated. Hopefully this wont happen again- but thanks to all those who have posted info on this site- its extremely helpful!!
  #4 (permalink)
Old 01-05-2010, 02:09 PM
Senior Expert
APP Volunteer
Default
Glad you got it fixed and while that was an expensive part, a tech visit would have cost you so much more.
Thanks for the update
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Oven clock and controls intermittently working wildbio1 Oven Repair (including Ranges and Cooktops) 1 01-29-2009 10:09 AM
Refrigerator controls not working richappy Refrigerator & Freezer Repair 2 10-21-2008 01:53 PM
Washer controls not working tripping breaker Spilly Washer Repair 1 08-18-2008 08:48 PM
Temp controls not working Rainman Refrigerator & Freezer Repair 0 06-04-2008 06:55 AM
Touch Pad Oven Controls Not Working MichaelAPP Oven Repair (including Ranges and Cooktops) 0 01-19-2008 02:57 PM
