Discuss
How to disable loud buzzer of Maytag Dryer model DE412?
 in
Dryer Repair
Hi. We have a Maytag, Heavy Duty Auto-Dry Dryer, model #DE412, which has an annoyingly LOUD buzzer. Given we have
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » How to disable loud buzzer of Maytag Dryer model DE412?
  #1 (permalink)
Old 12-24-2009, 10:18 AM
Junior Member
ocean is on a distinguished road
Default How to disable loud buzzer of Maytag Dryer model DE412?
Model Number: DE412   Brand: Maytag   Age: 1 - 5 years
Hi. We have a Maytag, Heavy Duty Auto-Dry Dryer, model #DE412, which has an annoyingly LOUD buzzer. Given we have to use it alot, including the the night we need to disable the buzzer so others in house are not being awoken by it.
I started to take off back screws from dryer back, according to general appliance repair book, only to realize that alone does not remove the back panel and its likely not suited for this dryer.
Then from a bit of research discovered the buzzer may(?) be located elsewhere on this particular dryer. But I still have yet to find where, and am concerned about which wire(s) to remove to disable dryer buzzer safely while keeping everything else working and safe.
Anyone know how to safely disable just the dryer buzzer for this particular Maytag dryer? Model # DE412.
( EDIT - I unscrewed the screws from back outside metal back of dryer only to realize that I would have had to take many more from sides to remove entire back of dryer which isnt even where buzzer is. So I tried to put the screws back into their places in back of dryer, including the two metal pieces covering open areas but only some screws fit back in for some reason. Given they would not go back in, i left a few screws out of their holes, but the one that says ground I never removed and is still in place.
After removing front top instrument panel and locating the buzzer, I removed both wires connecting to the buzzer and covered them with black electrical tape, per instructions in another forum.
But when we started dryer it makes a quiet sound but does not turn round.
So I opened the top front instrument panel cover again, saw nothing wrong and as i started to replace it it made a pop sound and an arc of electricity arced from panel to top of dryer.
That was unnerving. I dont know why that happened.
So I replaced one wire to the buzzer, leaving the other wire with electrical tape around it disconnected. But I dont know which way the wires connection attachments to buzzer are supposed to face when connected to the buzzer?
Does it matter if the metal wires connectors are with open area facing outward away from each other or inward toward each other on the buzzer?
Related Models
Maytag DE412 DRYER- ELE
Maytag DE482 DRYER- ELE
Maytag DE490 DRYER- ELE
Maytag DE4910 DRYER- ELE
Maytag DE50 DRYER- ELE
Maytag DE500 DRYER- ELE
Frigidaire DE500ADD5 Wwh(v4) / 27 " Electric Dryer
Frigidaire DE500ADD6 Wwh(v4) / 27 " Electric Dryer
Frigidaire DE500ADD7 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE500ADW5 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE500ADW6 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE500ADW7 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE500EDD1 Wwh(v16) / Electric Dryer
Frigidaire DE500EDD4 Wwh(v17) / Electric Dryer
Frigidaire DE500EDD5 Wwh(v18) / Electric Dryer
Frigidaire DE500EDF1 Wwh(v19) / Electric Dryer
Frigidaire DE500EDF4 Wwh(v20) / Electric Dryer
Frigidaire DE500EDF5 Wwh(v21) / Electric Dryer
Frigidaire DE500EDH1 Wwh(v22) / Electric Dryer
Frigidaire DE500EDH4 Wwh(v23) / Electric Dryer
Frigidaire DE500EDH5 Wwh(v24) / Electric Dryer
Frigidaire DE500EDV1 Wwh(v25) / Electric Dryer
Frigidaire DE500EDV4 Wwh(v26) / Electric Dryer
Frigidaire DE500EDV5 Wwh(v27) / Electric Dryer
Frigidaire DE500EDW1 Wwh(v28) / Electric Dryer
Frigidaire DE500EDW4 Wwh(v29) / Electric Dryer
Frigidaire DE500EDW5 Wwh(v30) / Electric Dryer
Frigidaire DE500JDD1 Wwh(v6) / Electric Dryer
Frigidaire DE500JDF1 Wwh(v7) / Electric Dryer
Frigidaire DE500JDH1 Wwh(v8) / Electric Dryer
Frigidaire DE500JDV1 Wwh(v9) / Electric Dryer
Frigidaire DE500JDW1 Wwh(v10) / Electric Dryer
Frigidaire DE500KDD1 Wwh(v7) / Electric Dryer
Frigidaire DE500KDD2 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE500KDD3 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE500KDD4 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE500KDD5 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE500KDD6 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE500KDH1 Wwh(v4) / Electric Dryer
Frigidaire DE500KDH2 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE500KDH3 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE500KDH4 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE500KDH6 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE500KDW1 Wwh(v1) / Electric Dryer
Frigidaire DE500KDW2 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE500KDW3 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE500KDW4 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE500KDW5 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE500KDW6 Wwh(v1) / 27 " Electric Dryer
Maytag DE510 DRYER- ELE
Maytag DE512 DRYER- ELE
Frigidaire DE5520RW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DE5520RW2 Frg(v1) / 27 " Electric Dryer
Frigidaire DE5800ADD1 Frg(v2) / 27 " Electric Dryer
Frigidaire DE5800AWW1 Frg(v3) / 27 " Electric Dryer
Frigidaire DE5800RW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DE5800RW2 Frg(v1) / 27 " Electric Dryer
Maytag DE590 DRYER- ELE
Maytag DE590D DRYER- ELE
Maytag DE5910 DRYER- ELE
Frigidaire DE600ADD2 Wwh(v4) / 27 " Electric Dryer
Frigidaire DE600ADD3 Wwh(v2) / 27 " Electric Dryer
Frigidaire DE600ADW2 Wwh(v3) / 27 " Electric Dryer
Frigidaire DE600ADW3 Wwh(v1) / 27 " Electric Dryer
Frigidaire DE600EDD1 Wwh(v1) / Electric Dryer
Frigidaire DE600EDD2 Wwh(v2) / Electric Dryer
Frigidaire DE600EDD4 Wwh(v3) / Electric Dryer
Frigidaire DE600EDD5 Wwh(v4) / Electric Dryer
Frigidaire DE600EDF1 Wwh(v5) / Electric Dryer
Frigidaire DE600EDF2 Wwh(v6) / Electric Dryer
Frigidaire DE600EDF4 Wwh(v7) / Electric Dryer
Frigidaire DE600EDF5 Wwh(v8) / Electric Dryer
Frigidaire DE600EDH1 Wwh(v9) / Electric Dryer
Frigidaire DE600EDH2 Wwh(v10) / Electric Dryer
Frigidaire DE600EDH4 Wwh(v11) / Electric Dryer
Frigidaire DE600EDH5 Wwh(v12) / Electric Dryer
Frigidaire DE600EDV1 Wwh(v13) / Electric Dryer
Frigidaire DE600EDV2 Wwh(v14) / Electric Dryer
Frigidaire DE600EDV4 Wwh(v15) / Electric Dryer
Frigidaire DE600EDV5 Wwh(v16) / Electric Dryer
Frigidaire DE600EDW1 Wwh(v17) / Electric Dryer
Frigidaire DE600EDW2 Wwh(v18) / Electric Dryer
Frigidaire DE600EDW4 Wwh(v19) / Electric Dryer
Frigidaire DE600EDW5 Wwh(v20) / Electric Dryer
Frigidaire DE600JDD1 Wwh(v1) / Electric Dryer
Frigidaire DE600JDF1 Wwh(v2) / Electric Dryer
Frigidaire DE600JDH1 Wwh(v3) / Electric Dryer
Frigidaire DE600JDV1 Wwh(v4) / Electric Dryer
Frigidaire DE600JDW1 Wwh(v5) / Electric Dryer
Frigidaire DE600KDD1 Wwh(v11) / Electric Dryer
Frigidaire DE600KDD2 Wwh(v9) / 27 " Electric Dryer
Frigidaire DE600KDD3 Wwh(v9) / 27 " Electric Dryer
Frigidaire DE600KDD4 Wwh(v9) / 27 " Electric Dryer
Frigidaire DE600KDD5 Wwh(v9) / 27 " Electric Dryer
Frigidaire DE600KDH1 Wwh(v7) / Electric Dryer
Frigidaire DE600KDH2 Wwh(v8) / 27 " Electric Dryer
Frigidaire DE600KDH3 Wwh(v8) / 27 " Electric Dryer
Frigidaire DE600KDH4 Wwh(v8) / 27 " Electric Dryer
Frigidaire DE600KDH5 Wwh(v8) / 27 " Electric Dryer
Frigidaire DE600KDW1 Wwh(v3) / Electric Dryer
Frigidaire DE600KDW2 Wwh(v7) / 27 " Electric Dryer
Frigidaire DE600KDW3 Wwh(v7) / 27 " Electric Dryer
Frigidaire DE600KDW4 Wwh(v7) / 27 " Electric Dryer
Frigidaire DE600KDW5 Wwh(v7) / 27 " Electric Dryer
Amana DE6050 WASHER-TOP LOADING
Amana DE6051 WASHER-TOP LOADING
Maytag DE606 DRYER- ELE
Maytag DE608 DRYER- ELE
Amana DE6080 WASHER-TOP LOADING
Amana DE6081 WASHER-TOP LOADING
Maytag DE610 DRYER- ELE
Maytag DE612 DRYER- ELE
Amana DE6151 WASHER-TOP LOADING
Amana DE6171 WASHER-TOP LOADING
Frigidaire DE620EXD1 Wwh(v1) / Gas and Electric Dryers
Frigidaire DE620EXD2 Wwh(v2) / Gas and Electric Dryers
Frigidaire DE620EXD3 Wwh(v3) / Gas and Electric Dryers
Frigidaire DE620EXW1 Wwh(v4) / Gas and Electric Dryers
Frigidaire DE620EXW2 Wwh(v5) / Gas and Electric Dryers
Frigidaire DE620EXW3 Wwh(v6) / Gas and Electric Dryers
  #2 (permalink)
Old 12-24-2009, 09:33 PM
Junior Member
Default
Here are some photos I took of the wires that connect to the buzzer, after I disconnected them.
I am not sure which way they are supposed to connect, open end of metal connections facing each other, facing away from each other, or both facing same same direction?
  #3 (permalink)
Old 12-25-2009, 04:31 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
If the lugs have a small stud on it, it goes to the back side of the receptacle (closed side) though normally they are tight enough that it makes no difference.
I would take the side you have taped off and and tape it onto the main harness.
__________________
  #4 (permalink)
Old 12-26-2009, 07:46 PM
Junior Member
Default
Sorry, but I do not understand what you mean.
Basically, one of my questions is where does the single grey wire to the buzzer box, attach on the buzzer box posts?
Does the single grey wire from the box to the right of it with many wires coming from / in it, go onto the buzzer box right or left metal attachments? And thus the remaining combined blue and black wires ( the blue wire from item to right of buzzer box in photos above, and the black wire coming from back below inside dryer ) go into the left or right side metal prong on buzzer box?
Also, would the inability to replace 3 or 4 screws from back, outward facing side of metal wall of the dryer cause a short or it to malfunction, not rotate? For some reason after taking some of these screws out ( mistakenly thinking I needed to take the whole panelling of dryer off to get at buzzer before realizing the buzzer is behind control panel at top ) they would not fit back into their holes. Like panelling shifted position just a fraction of an inch to far to fit back. But the one screw that I never removed which says ground screw next to it is still in place.
I also removed the two grey metal panels that exposed wires, but put them back on except for two screws on top right panel which seems to only attach by one screw now as others dont fit either. But I did not actually touch or alter any wiring in the back / inside of dryer. Only the top behind control panel of dryer where buzzer box is, taking them off.
  #5 (permalink)
Old 12-27-2009, 02:27 AM
Senior Expert
APP Volunteer
Default
On your original post I thought you were asking how the receptacles attach to the buzzer lugs. Basically it makes no difference as long as they are tight,
I suggested taping them up onto the main harness so that when the control panel is re-assembled they sit horizontally. Then it is less likely that the tape over time will come loose, drop off and cause a short.
It should not make any difference.
Leaving out some screws may have caused an internal electrical connection to short to the frame when you reassembled the unit. Look for the telltale sign of a scorch or arc mark. Also check that where the wires from the console enter the main body of the unit that there is not a wire worn through and touching the frame. It could also be that a wire has pulled loose inside the main unit.
Do not put it together or take it apart with the unit plugged in. If hard wired flip the breaker.
But when we started dryer it makes a quiet sound but does not turn round. I would remove the tape from the double buzzer connection and check that it is OK.
If good I would re-tape it and tape up the other connector and then tape those to the main harness.
If you are sure it was an electrical arc that caused the pop then you will have to find where it was and repair the cause.
Without being there I cannot say what is currently wrong but you hear a "quiet sound", it could be that the motor is actually running but the belt has broken.
Usually when a motor cannot start for some reason it will buzz.
Here is a good site with dryer repair help
http://www.applianceaid.com/dryers.html
PS: I am off to the lake for a week and will be unavailable. If you need more help and do not get a timely answer, you may want to start a new thread referring back to this one. When it is busy or some regular posters are off, we do not have the time to check posts that someone else has been responding to.
__________________
  #6 (permalink)
Old 12-28-2009, 09:40 AM
Junior Member
Default
Thank you very much for your thorough response.
I tried the dryer again today, only to discover that now nothing at all happens after plugging power cord back in dryer, with both wires reattached, as well as when unattached, to buzzer box, when i push the start button. Not even a tiny sound of any type.
Seems something else has happened that totally preventing the dryer from doing anything at all. Any ideas why or how to repair in this situation?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dryer Model#MDE9806AYW lvwalrus Dryer Repair 7 05-18-2010 05:54 PM
Disconnect Maytag dryer buzzer jdswartz Dryer Repair 2 11-27-2009 01:21 PM
model dg 312 Maytag dryer - reset pilot R T Lannen Dryer Repair 0 06-11-2009 11:16 AM
how to disable Whirlpool end-of-cycle buzzer? dan g Dryer Repair 1 01-23-2009 11:56 AM
howw to remove front panel of Maytag DE412 electric dryer Steinar Huang Dryer Repair 1 07-17-2008 06:33 PM
