Discuss
Blows air but it's cold!
 in
Dryer Repair
Just wanting a heads up for what to test/replace first.....the air is blowing and the drum is turning, but the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Blows air but it's cold!
  #1 (permalink)
Old 12-22-2009, 07:58 AM
Junior Member
Palmettoquilter is on a distinguished road
Default Blows air but it's cold!
Model Number: 110.86621100   Brand: Kenmore   Age: More than 10 years
Just wanting a heads up for what to test/replace first.....the air is blowing and the drum is turning, but the air is always cold. Just happened 24 hours ago, suddenly.
Would you think it was the thermal fuse? Look at that before the element? Can I test across it with my tester with the light in it, will that tell me anything?
Thanks for any help you can give!
Ads By Google
Related Models
Kenmore 110.87405140  GAS DRYER
Kenmore 110.87405160  COMMERCIAL GAS DRYER
Kenmore 110.87405840  GAS DRYER
Kenmore 110.87405860  COMMERCIAL GAS DRYER
Kenmore 110.87407140  GAS DRYER
Kenmore 110.87407840  GAS DRYER
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
Kenmore 11020097991 WASHER
Kenmore 11020097992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
  #2 (permalink)
Old 12-22-2009, 06:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would do is check for 240 VAC to dryer. The heating element needs 240 VAC while the motor needs just 120 VAC. Make sure both breakers are On.
You have to have a multimeter. I'm not sure about your tester, I never used a such.
If there is nothing wrong with the voltage, then you have to check for continuity the heating element, the high limit thermostat and the cycling thermostat.
This is definitely not the thermal fuse, because the dryer would not do anything if this fuse is blown.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-22-2009, 10:11 PM
Junior Member
Question update on electric dryer
Hi Gene,
Thanks for responding. I found an analog ohmeter and found a spot on the web that instructed me in adjusting it, and using it. On the thermal fuse, the high limit thermostat, and the connection to the heater element, the meter needle swung over to 0 just as it should. On the cycling thermostat, it didn't move. I took it out and matched it to a new one at a parts place in town. Just before installing it, I put the ohmeter on the new one - checked OK. Believe it or not, when I put it on the old one again, it checked out OK!!!! I re-installed it and the dryer blows nice hot air!
What in the world happened?! I'm happy for the new life in the old dryer, but apprehensive it may happen again?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Won't Heat, Blows Cold Air ramonamahoney@rocketmail. Dryer Repair 4 01-29-2010 01:33 AM
dryer blows but its cold just happend billy31 Dryer Repair 1 12-23-2009 05:02 AM
Dryer heat blows hot then cold scri8e Dryer Repair 0 03-09-2009 01:07 PM
dryer blows cold air won't advance through cycle sandra626 Dryer Repair 4 02-05-2008 10:49 AM
freezer blows cold then hot tambo Refrigerator & Freezer Repair 0 11-12-2007 03:59 AM
