Myers12
#1 Posted : Monday, December 21, 2009 4:38:53 PM(UTC)
Myers12
My dryer quit heating, checked the breaker - that is fine. Want to replace heater element but unable to remove old one after removing screws. Is there a trick to remove old element? Your help would be appreciated.
Myers12
#2 Posted : Monday, December 21, 2009 4:40:32 PM(UTC)
Myers12
My dryer quit heating, checked the breaker - that is fine. Want to replace heater element but unable to remove old one after removing screws. Is there a trick to remove old element? Your help would be appreciated. Model #GEW9868KQ0/Whirlpool
#3 Posted : Tuesday, December 22, 2009 3:59:22 AM(UTC)
Did you remove the screw on the side.
See Page 4-10 in the below, different unit but I beleive the heaters are the same
https://secured.whirlpoo...64beaa/$FILE/Duetdry.pdf
trent13az
#4 Posted : Monday, January 18, 2010 3:33:24 PM(UTC)
trent13az
How can I be sure that it is just the dryer heating element or just the thermal cut-off (352 degrees) or high-limit thermostat (250 degrees) and not all of them? I know that buying all 3 would cost me $70+/-, or is it wise to replace all of them since I'll be in there? Thanks!
#5 Posted : Monday, January 18, 2010 4:06:51 PM(UTC)
Measure them with a meter.
The heating element should be around 10 ohms
Both the hi-limit and cut-off should be 0 ohms
Note it the thermal cut-off is blown you have to find the cause of it blowing.
Unplug the unit and both wires to the heating coil.
Check it with a meter, should be around 10 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the heater is OK then I would also replace the hi-limit thermostat as this should have regulated the temperature so that the fuse did not blow.
You still have to find the cause.
It could be:
A dirty/loose blower wheel
A dirty vent system or it's outside louvers are not opening.
A bad cycling (control) thermostat. Note this is a 4 connector thermostat.
One set is the contacts. The other set is the internal heater, should be around 25,000 ohms. This is used to give you different heat settings.
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
