richgolen@gmail.com
#1 Posted : Monday, December 21, 2009 9:28:00 AM(UTC)
richgolen@gmail.com
Have 72 ohms across igniter continuity across flame sensor no lint buildup on burner dryer operates but still no heat any suggestions?
#2 Posted : Monday, December 21, 2009 11:52:41 AM(UTC)
Remove the rear panel and check the thermal fuse (#7 on the diagram) for continuity. If it's open, replace it together with the cycling thermostat (#9) and make sure the vent line is clean all the way through the outlet.
- The thermal fuse Part number: AP3132867
- The cycling thermostat Part number: AP3131939
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
