Discuss
Lint bypassing lint screen
 in
Dryer Repair
I have a 3yr old Whirlpool Cabrio dryer. For the past 4 months I have been having problems with the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Lint bypassing lint screen
  #1 (permalink)
Old 12-20-2009, 07:05 PM
Junior Member
mlciancar is on a distinguished road
Default Lint bypassing lint screen
Brand: Whirlpool   Age: 1 - 5 years
I have a 3yr old Whirlpool Cabrio dryer. For the past 4 months I have been having problems with the lint bypassing my lint screen and going directly into the piping in my wall. I have had a contractor come out 4 times to clean out the pipe in my wall and the vent that leads outside. Everytime I pull the lint screen out after a cyle it only has lint in one corner of the screen. I have had a tech out who said there was nothing wrong with my dryer. All he did was disconect it from the wall and said that becuase it was not showing any airflow problem disconected form the wall that my dryer was fine. He totally disregarded the point of the lint screen not collecting the lint. I am very frustrated and have spent 100's of dollors cleaning my vent and on repair technicians. I have ordered a new lint screen but am still waiting for it. I am debating calling another tech to come out to the house. Meanwhile I have my dryer hooked up to a dryer hose leading out my window because I don't want to clog the one in my wall again and cause a fire. Can you please help.
Thank you so much!
Lisa C
  #2 (permalink)
Old 12-21-2009, 03:17 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is a service manual
https://secured.whirlpool.com/Servic...LE/8178584.pdf
Here is a bulletin on this problem
https://secured.whirlpool.com/Servic...D09_LP_001.pdf
With a little luck the new filter will fix the problem.
If not then all I can suggest is that the air chute (Item 1 in Section 3) be pulled out of the unit and inspected. Perhaps it has a problem with the filter fitting inside properly..
If the chute has to be pulled be sure to clean/check the blower wheel as it is probably also getting clogged with lint.
__________________
  #3 (permalink)
Old 12-21-2009, 06:53 AM
Junior Member
Default Thank you!
thank you so much. I just received and email that my filter was on backorder but may be available on 12./20. Let's hope this does the trick.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
lint screen spring jm26124 Dryer Repair 2 06-11-2015 11:06 PM
New lint screen not working dubois6789 Dryer Repair 1 02-25-2010 03:06 PM
only part of lint screen catching lint edmoore Dryer Repair 1 11-17-2009 08:47 AM
hairbrush dropped down lint screen puddles2001 Dryer Repair 1 06-09-2009 10:12 AM
Lint Screen Housing chetterogo Dryer Repair 3 04-24-2008 06:24 PM
