Discuss
Kenmore wont heat
 in
Dryer Repair
Dryer runs but no heat. The thermal cut-off was open, so I replaced it and thermostat. Still no heat.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore wont heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-20-2008, 10:11 AM
seagrove seagrove is offline
Junior Member
seagrove is on a distinguished road
Default Kenmore wont heat
Model Number: 110.63942101   Brand: Kenmore   Age: 5 - 10 years
Dryer runs but no heat. The thermal cut-off was open, so I replaced it and thermostat. Still no heat. Tested all other componentsdescribed in tech sheet. Guessed it may be the even heat control board, but went back and tested the new thermal cut-off - open again. What could be blowing it?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-20-2008, 06:36 PM
bambiblaster bambiblaster is offline
Senior Expert
APP Volunteer
bambiblaster is on a distinguished road
Default
Remove 1 wire from element and touch meter leads to element and to heater housing and the other element connector to housing .. element may be shorted to the housing.. if you get continuity it is...
  #3 (permalink)
Old 03-21-2008, 05:45 AM
Junior Member
Default
Thank you. I tested the element and found no short.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 60 Series(gas) Runs but wont heat PJM Dryer Repair 0 02-02-2008 06:09 AM
kenmore wont work gatemindr1 Dishwasher Repair 0 01-26-2008 06:16 AM
new heater but wont heat up bri_w_4 Dryer Repair 0 01-14-2008 03:19 PM
microwave wont heat chrispeach Microwave Repair 1 11-07-2007 10:49 AM
Dryer wont heat mike54487 Dryer Repair 1 10-09-2007 02:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
