Eugene P
#1 Posted : Sunday, December 20, 2009 10:49:57 AM(UTC)
Eugene P
I have an old GE electric dryer. It heats hot at the beginning and then cools off early. It usually takes about 2 heating cycles at 75 min to dry clothes. Any suggestions would help. Thanks
#2 Posted : Monday, December 21, 2009 1:20:05 AM(UTC)
The most common cause of long dry times is a dirty/malfunctioning vent system.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
Eugene P
#3 Posted : Wednesday, December 30, 2009 4:39:49 PM(UTC)
Eugene P
Thank you. Just got the post. I will check the dryer in the next few days. Have a great New Year!
HELP! electric dryer will not heat (Dryer Repair)
by jaegray369 3/27/2012 6:31:52 PM(UTC)
Electric Dryer will not heat (Dryer Repair)
by dmerritt8712 3/26/2012 9:35:58 AM(UTC)
Whirlpool Electric Dryer will not heat (Dryer Repair)
by scramjet 8/21/2011 1:25:38 PM(UTC)
Electric Dryer will not heat up (Dryer Repair)
by varn99 6/2/2011 3:26:17 PM(UTC)
by sz9pm3 11/11/2010 3:32:53 PM(UTC)
Electric Dryer will not heat and timer does not count down (Dryer Repair)
by wes_cul 1/26/2010 5:08:31 PM(UTC)
Electric Dryer will not heat but runs fine! (Dryer Repair)
by dcrenlop 7/19/2009 1:51:32 PM(UTC)
by Shep 4/14/2009 10:37:42 AM(UTC)
by JOYCENAPIER 10/14/2008 12:35:51 PM(UTC)
