abilene56
#1 Posted : Saturday, December 19, 2009 9:58:18 AM(UTC)
abilene56
My dryer just stopped drying clothes. I am thinking it is the element but need a schematic and any other advice available!
#2 Posted : Sunday, December 20, 2009 5:29:39 AM(UTC)
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208545908.pdf
Could be the heater, thermal fuse. hi-limit thermostat, heater relay control board or motor's centrifugal switch.
First thing to do is flip your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing check the power at the plug,
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip
If OK
Measure the voltage at the terminal strip
If OK
Unplug the unit and check the heating coil and the fuse/thermostats
If OK
Swap the motor relay for the heater relay if the unit now will not start you know that the relay is toast.
