| » Dryer will not heat |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: GGQ9880LG1 Brand: Whirlpool Age: 1 - 5 years
Dryer runs but no heat. Checked the following:
thermal fuse = closed Igniter = closed Flame sensor = Closed thermal fuse = closed Gas valve coils check OK cycling thermostat = closed across red and open across vilot Timer checks OK It has gas because I have been about to mess around and get it to fire but cannot recreat my messing around Local appliance repair man is on a cruise??? Any suggestions? |
If the igniter glows and there is gas to the dryer but it does not light then the only failure suspect left is the gas valve.
- The part number for the gas valve is AP3083221 Here are the break down diagrams for the Whirlpool dryer Model GGQ9800LG1 Gene.
__________________
Professional appliance repair services in Orange County, California. |
Check the temperature switch on the control panel.
Also the cycling thermostat has to be replaced due to: "open across violet". - The part number for the temperature switch is AP2947360 - The part number for the cycling thermostat is AP3045874 Gene.
__________________
| Display Modes | |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 9 | 03-22-2008 11:40 AM |
| Dryer does not heat | puddinhd58 | Dryer Repair | 1 | 03-01-2008 03:38 PM |
| Dryer will run but not heat | allansc | Dryer Repair | 12 | 12-28-2007 06:10 PM |
| Estate Dryer by Whirlpool/Dryer running but no heat | tsm11238 | Dryer Repair | 1 | 11-06-2007 10:47 AM |
| dryer doesn't heat | undertaker | Dryer Repair | 0 | 10-22-2007 10:54 AM |
