tlrplus@comcast.net
#1 Posted : Friday, December 18, 2009 6:50:30 AM(UTC)
tlrplus@comcast.net
Dryer not heating up. Replaced heating element. Still does not heat up. Any suggestions what else it could be.
#2 Posted : Friday, December 18, 2009 8:35:04 AM(UTC)
Replacement parts for WHIRLPOOL TEDX640PQ1 29"electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208576793.pdf
Have you checked the power at the plug, L1 to L2 should be 240 volts.
Ir the timer does not advance in timed dry mode then this may be your problem as the timer in this unit uses 240 volts.
Check the operating thermostat, hi-limit thermostat and the thermal fuse.
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 Yesterday at 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Maytag electirc dryer model LDE9334ACM (Dryer Repair)
by Guest 3/22/2024 6:07:19 PM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
Frigidaire Front Load Dryer aeq6000es2 (Dryer Repair)
by Guest 3/3/2024 7:28:15 AM(UTC)
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 3/2/2024 3:42:02 PM(UTC)
samsung dryer Dv48H (Dryer Repair)
by Guest 2/27/2024 6:11:07 PM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
