Discuss
dryer heats for short time
 in
Dryer Repair
Dryer heats up for short time then goes cool. We replaced the heating element and coils. We checked the venting
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer heats for short time
  #1 (permalink)
Old 12-15-2009, 10:55 AM
Junior Member
shellbutton is on a distinguished road
Default dryer heats for short time
Model Number: lgr6620pq1   Brand: Whirlpool   Age: 1 - 5 years
Dryer heats up for short time then goes cool. We replaced the heating element and coils. We checked the venting everything is good there also? Timer switch doesn't move and continues to run, what am i overlooking? Repairman wants to charge $85.00 for the first 15 minutes, please help!!!!!
Related Models
Whirlpool LGR6620PQ1 29"GAS DRYER
Whirlpool LGR6620PT0 29"GAS DRYER
Whirlpool LGR6620PT1 29"GAS DRYER
Whirlpool LGR6621PQ0 29" GAS DRYER
Whirlpool LGR6634BN0 GAS DRYER
Whirlpool LGR6634BN1 GAS DRYER
Whirlpool LGR6634BN2 GAS DRYER
Whirlpool LGR6634BQ0 GAS DRYER
Whirlpool LGR6634BQ1 GAS DRYER
Whirlpool LGR6634BQ2 GAS DRYER
Whirlpool LGR6634BW0 GAS DRYER
Whirlpool LGR6634BW1 GAS DRYER
Whirlpool LGR6634BW2 GAS DRYER
Whirlpool LGR6634DQ0 GAS DRYER
Whirlpool LGR6634DQ1 GAS DRYER
Whirlpool LGR6634DW0 GAS DRYER
Whirlpool LGR6634DW1 GAS DRYER
Whirlpool LGR6634DZ0 GAS DRYER
Whirlpool LGR6634DZ1 GAS DRYER
Whirlpool LGR6636PW0 29" GAS DRYER
Whirlpool LGR6636PW1 29" GAS DRYER
Whirlpool LGR6638DQ0 GAS DRYER
Whirlpool LGR6638DQ1 GAS DRYER
Whirlpool LGR6638DW0 GAS DRYER
Whirlpool LGR6638DW1 GAS DRYER
Whirlpool LGR6638DZ0 GAS DRYER
Whirlpool LGR6638DZ1 GAS DRYER
Whirlpool LGR6644DQ0 GAS DRYER
Whirlpool LGR6644DQ1 GAS DRYER
Whirlpool LGR6644DZ0 GAS DRYER
Whirlpool LGR6644DZ1 GAS DRYER
Whirlpool LGR6646BN0 GAS DRYER
Whirlpool LGR6646BN1 GAS DRYER
Whirlpool LGR6646BN2 GAS DRYER
Whirlpool LGR6646BW0 GAS DRYER
Whirlpool LGR6646BW1 GAS DRYER
Whirlpool LGR6646BW2 GAS DRYER
Whirlpool LGR6646DN1 GAS DRYER
Whirlpool LGR6646DW1 GAS DRYER
Whirlpool LGR6646PW0 29" GAS DRYER
Whirlpool LGR6646PW1 29" GAS DRYER
Whirlpool LGR6848AN1 GAS DRYER
Whirlpool LGR6848AN2 GAS DRYER
Whirlpool LGR6848AQ2 GAS DRYER
Whirlpool LGR6848AW0 Residential Dryer
Whirlpool LGR6848AW1 GAS DRYER
Whirlpool LGR6848AW2 GAS DRYER
Whirlpool LGR6848AZ2 GAS DRYER
Whirlpool LGR7620KQ0 RESIDENTIAL DRYER
Whirlpool LGR7620KQ1 RESIDENTIAL DRYER
Whirlpool LGR7620KT0 RESIDENTIAL DRYER
Whirlpool LGR7620KT1 RESIDENTIAL DRYER
Whirlpool LGR7620LG0 RESIDENTIAL DRYER
Whirlpool LGR7620LG1 29"GAS DRYER
Whirlpool LGR7620LQ0 RESIDENTIAL DRYER
Whirlpool LGR7620LW0 RESIDENTIAL DRYER
Whirlpool LGR7620LW1 29"GAS DRYER
Whirlpool LGR7645JQ0 GAS DRYER
Whirlpool LGR7645JQ1 GAS DRYER
Whirlpool LGR7645JQ2 DRYER
Whirlpool LGR7646AN0 GAS DRYER
Whirlpool LGR7646AN1 GAS DRYER
Whirlpool LGR7646AN2 GAS DRYER
Whirlpool LGR7646AQ0 GAS DRYER
Whirlpool LGR7646AQ1 GAS DRYER
Whirlpool LGR7646AQ2 GAS DRYER
Whirlpool LGR7646AW0 Residential Dryer
Whirlpool LGR7646AW1 GAS DRYER
Whirlpool LGR7646AW2 GAS DRYER
Whirlpool LGR7646AZ0 GAS DRYER
Whirlpool LGR7646AZ1 GAS DRYER
Whirlpool LGR7646AZ2 GAS DRYER
Whirlpool LGR7646DQ0 GAS DRYER
Whirlpool LGR7646DQ1 GAS DRYER
Whirlpool LGR7646DW0 GAS DRYER
Whirlpool LGR7646DW1 GAS DRYER
Whirlpool LGR7646DZ0 GAS DRYER
Whirlpool LGR7646DZ1 GAS DRYER
Whirlpool LGR7646EQ0 DRYER
Whirlpool LGR7646EQ1 DRYERS
Whirlpool LGR7646EQ2 GAS DRYER
Whirlpool LGR7646EQ3 GAS DRYER
Whirlpool LGR7646EZ0 DRYER
Whirlpool LGR7646EZ1 DRYERS
Whirlpool LGR7646EZ2 GAS DRYER
Whirlpool LGR7646EZ3 GAS DRYER
Whirlpool LGR7646JQ0 GAS DRYER
Whirlpool LGR7646JQ1 RESIDENTIAL DRYER
Whirlpool LGR7646JT0 GAS DRYER
Whirlpool LGR7646JT1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ0 RESIDENTIAL DRYER
Whirlpool LGR7648KQ1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ2 29"GAS DRYER
Whirlpool LGR7648KT0 RESIDENTIAL DRYER
Whirlpool LGR7648KT1 RESIDENTIAL DRYER
Whirlpool LGR7648KT2 29"GAS DRYER
Whirlpool LGR7648PQ0 29" GAS DRYER
Whirlpool LGR7648PQ1 29" GAS DRYER
Whirlpool LGR7648PT0 29" GAS DRYER
Whirlpool LGR7648PT1 29" GAS DRYER
Whirlpool LGR7848DQ0 GAS DRYER
Whirlpool LGR7848DQ1 GAS DRYER
Whirlpool LGR7848DZ0 GAS DRYER
Whirlpool LGR7848DZ1 GAS DRYER
Whirlpool LGR7858AN1 GAS DRYER
Whirlpool LGR7858AN2 GAS DRYER
Whirlpool LGR7858AW0 Residential Dryer
Whirlpool LGR7858AW1 GAS DRYER
Whirlpool LGR7858AW2 GAS DRYER
Whirlpool LGR8620PG0 29"GAS DRYER
Whirlpool LGR8620PG1 29"GAS DRYER
Whirlpool LGR8620PW0 29"GAS DRYER
Whirlpool LGR8620PW1 29"GAS DRYER
Whirlpool LGR8646LG0 RESIDENTIAL DRYER
Whirlpool LGR8648LG1 29"GAS DRYER
Whirlpool LGR8648LQ0 RESIDENTIAL DRYER
Whirlpool LGR8648LW0 RESIDENTIAL DRYER
Whirlpool LGR8648LW1 29"GAS DRYER
Whirlpool LGR8648PG0 29"GAS DRYER
Whirlpool LGR8648PG1 29" Gas Dryer
  #2 (permalink)
Old 12-17-2009, 06:24 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
The first thing I would do is check and see if this happens in all cycles, and if not tell us in which ones it does.
This may be a situation where you have to replace some parts on speculation, but see what you can tell us first about when this happens.
Your post is also a little confusing, are you saying the timer does not move but the dryer continue to turn, blowing cold air?
__________________
  #3 (permalink)
Old 12-18-2009, 08:39 AM
Junior Member
Default cycles
The only time the timer doesn't move is on the towel or high heat setting. I do not get heat on the other cycles but for 2 to 3 minutes. Yes to the last question...... the dryer continues to run and I get no heat.
  #4 (permalink)
Old 12-18-2009, 09:12 AM
Senior Expert
APP Volunteer
Default
Given that it starts to heat, I think this part is likely the problem. If it did not heat at all it would be easy to test continuity, but you will probably get false readings.
Part number: AP3131939
Do check with a meter to see that you have 120v at each side of the connection block and that your hi limit thermostat and thermal cut off have continuity.
__________________
  #5 (permalink)
Old 01-01-2010, 07:45 AM
Junior Member
Default dryer won't stay hot
So I checked the thermostat that is fine, I replaced the heating element and the coils. What else can I look at with this dryer? Like I said it heats for maybe a couple minutes, and all I get is cold air.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer only heats for short periods of time, if at all. fred2117 Dryer Repair 3 05-01-2009 06:20 AM
Elec Dryer Stops after short time shews01 Dryer Repair 1 03-19-2009 02:25 AM
dryer heats but runs for a short time suckleh0nny Dryer Repair 8 11-10-2008 07:42 PM
gas dryer only heats up for short periods gregn Dryer Repair 0 08-01-2008 02:27 PM
dryer quits running after a short time magictickler Dryer Repair 1 10-01-2007 02:48 AM
