Discuss
troubleshooting broken dryer belt
 in
Dryer Repair
We have a Maytag Performa that stopped spinning. The belt is loose and all shredded so we assumed we just
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » troubleshooting broken dryer belt
  #1 (permalink)
Old 12-14-2009, 06:02 PM
Junior Member
mathair4 is on a distinguished road
Default troubleshooting broken dryer belt
Model Number: PYG2300AWW   Brand: Maytag   Age: 1 - 5 years
We have a Maytag Performa that stopped spinning. The belt is loose and all shredded so we assumed we just need a new belt. When we took the dryer apart we checked the other parts. The idler pulley ( that's the plastic one on the idler arm right?) seems to spin fine. The motor runs fine. But when we stretch the broken belt around the motor pulley and idler pulley, and turn on the dryer, the motor pulley doesn't seem to spin. Is that normal? Is it just because the belt is broken? We are trying to assess if the broken belt is the only problem, or if there is something else wrong that caused the belt to break. My husband seems to think that the motor pulley only engages and spins a bit when we turn the dryer to "off."
Ads By Google
Related Models
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
Whirlpool R183
Whirlpool R183A
Whirlpool R183A1
Whirlpool R183A2
Whirlpool R183A3
Whirlpool R183F0
Whirlpool R183G0
Whirlpool R183G1
Amana R1E Mwave - Family Size (60 Hz)
Jenn-Air R200 Surface Unit - Ddraft Ele
Frigidaire R2000DL0 Frg(v1) / Electric Range
Frigidaire R2000DW0 Frg(v2) / Electric Range
Frigidaire R2000LL1 Frg(v1) / Electric Range
Frigidaire R2000LW1 Frg(v2) / Electric Range
Jenn-Air R201 Surface Unit - Ddraft Ele
Jenn-Air R201-C Surface Unit - Ddraft Ele
Frigidaire R21CL0 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL1 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL2 Frg(v2) / Electric Range
Frigidaire R21CL3 Frg(v4) / Electric Range
Frigidaire R21CL4 Frg(v6) / Electric Range
Frigidaire R21CL5 Frg(v2) / Electric Range
Frigidaire R21CL6 Frg(v4) / Electric Range
Frigidaire R21CW0 Frg(v2) / Free Standing Electric Range
Frigidaire R21CW1 Frg(v2) / Free Standing Electric Range
Frigidaire R21CW2 Frg(v1) / Electric Range
Frigidaire R21CW3 Frg(v3) / Electric Range
  #2 (permalink)
Old 12-17-2009, 06:19 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I am a little confused by your post, but it sounds like your motor pulley is not attached to the motor correctly. When the motor spins the pulley must spin to turn the belt to turn the drum. The bad pulley may have caused your belt problem.
Fortunately the motor pulley on your model is separate from the motor, otherwise the cost is much higher. Here is the pulley for your motor.
Part number: AP4039058
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
broken dryer belt gmandunn007@aol.com Dryer Repair 1 07-13-2009 01:10 PM
Dryer belt broken? jmilstead Dryer Repair 7 01-15-2009 05:41 AM
broken belt mpsals1111 Dryer Repair 1 07-20-2008 02:44 AM
Whirlpool gas dryer won't turn, broken belt? crusader66 Dryer Repair 1 06-23-2008 03:39 AM
Broken belt Carlos Washer Repair 3 03-13-2008 06:28 PM
