Discuss
Dryer quit, and smelled burned
 in
Dryer Repair
I took out the drum to get at the ("t-stat safe" part# AP2619437 - it checked open. !) (The
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer quit, and smelled burned
  #1 (permalink)
Old 03-17-2008, 09:17 PM
hotpointdryer hotpointdryer is offline
Junior Member
hotpointdryer is on a distinguished road
Exclamation Dryer quit, and smelled burned
Model Number: DLB2880DGL   Brand: Hotpoint   Age: More than 10 years
it checked open. !) (The high limit tested closed.) Neither was grounded or smelled burned. The motor was not grounded and show 0 "ohms" between the leads.
What the heck happened. to make this dryer just quit and smell burned ?........
P.S. ( The breaker box is OK ) it didn't blow the breaker.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-18-2008, 01:38 PM
johnl johnl is offline
Junior Member
johnl is on a distinguished road
Default
First off I'm not a tech. Perhaps... Heater element overheated, causing safety fuse to burn out (go open). If that happened, maybe because of a restriction in the ducting limiting airflow, or, bad high limit t-stat.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
burned out VPruitt Refrigerator & Freezer Repair 1 02-11-2008 12:59 PM
Glass cooktop burned will not turn off. CELESTE RC Oven Repair (including Ranges and Cooktops) 10 01-24-2008 09:47 AM
Burned out oven thermostat, I think NVP Oven Repair (including Ranges and Cooktops) 1 01-07-2008 04:56 PM
Vynil Flooring is burned through under refrigerator David McCullough Refrigerator & Freezer Repair 1 11-16-2007 07:40 PM
maytag dryer quit working james001 Dryer Repair 1 10-18-2007 04:01 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
