Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   drum will not spin (http://forum.appliancepartspros.com/dryer-repair/64-drum-will-not-spin.html)
maria camacho 07-20-2007 06:54 PM
drum will not spin
dryer will heat up but drum will not spin clothes
Gene 07-20-2007 09:56 PM
Maria Camacho
In order to help you better we need the complete model number of your dryer. You can find it on the door frame, on top of the console or on the right side of the cabinet on the very bottom.
Unfortunately the model number you supplied is incorrect.
Zandra 11-02-2011 09:19 AM
ggq8858eq1 is the model number
Zandra 11-02-2011 09:26 AM
dryer drum is not spinning
magician59 11-02-2011 09:31 AM
Put the timer on a "No Heat", or "Air Fluff" cycle. Start the dryer and see if you hear the motor. If you heaar the motor, you have a broken belt. If there's no motor noise, you'll need to replace the motor.
Part number: AP2946843
Part number: AP3094245
Zandra 11-02-2011 09:35 AM
Thank you so much. We will try that.
