found the factory diagram taped to /in dryer . and did not mark wires. temp/fabric selector switch,terminals not well defined in diagram. switch has spade terminals marked as follows: AH6, .AH1, AH3, .AH (AH3 has resistor connected) one heavy red wire comes from the timer one white/blue wire comes from the timer one heavy red goes to the temp overload one white/purple goes to a four wire splice need to know which wire to which terminal
thanks mothers growing impatiant
