Discuss
Whirlpool thin twin stackable washer and dryer
 in
Dryer Repair
On the tag it 120/240 volts 27 amps 60 HZ. My question is can it be wired for either 120
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool thin twin stackable washer and dryer
  #1 (permalink)
Old 12-13-2009, 10:50 AM
Junior Member
numisman1@yahoo.com is on a distinguished road
Default Whirlpool thin twin stackable washer and dryer
Model Number: lte6234dq1   Brand: Whirlpool   Age: 5 - 10 years
On the tag it 120/240 volts 27 amps 60 HZ. My question is can it be wired for either 120 or 240 volts. There is only 120 in the house it is going into. So I need to know before I get it .
Thank you.
Tom
Ads By Google
Related Models
Whirlpool LTE6234DQ1
Whirlpool LTE6234DQ2
Whirlpool LTE6234DQ3 Washer/dryer Laundry System
Whirlpool LTE6234DQ4 Washer/dryer Laundry System
Whirlpool LTE6234DQ5 Washer/dryer Laundry System
Whirlpool LTE6234DQ6 Washer/dryer Laundry System
Whirlpool LTE6234DT2
Whirlpool LTE6234DT3 Washer/dryer Laundry System
Whirlpool LTE6234DT4 Washer/dryer Laundry System
Whirlpool LTE6234DT5 Washer/dryer Laundry System
Whirlpool LTE6234DT6 Washer/dryer Laundry System
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1
Whirlpool LTE6234DZ2
Whirlpool LTE7245AN0
Whirlpool LTE7245AW0
Whirlpool LTE7800W1
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB Ref - Top Mount
Admiral LTF1812ARW Ref - Top Mount
Admiral LTF1812ARZ Ref - Top Mount
Admiral LTF2112ARB Ref - Top Mount
Admiral LTF2112ARW Ref - Top Mount
Admiral LTF2112ARZ Ref - Top Mount
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1
Whirlpool LTG7245AN0
Whirlpool LTG7245AW0
Whirlpool LUD2100X0
Whirlpool LUD2100X1
Whirlpool LUD2100X3
Whirlpool LUD2100X4
Whirlpool LUD2100X5
Whirlpool LUD2100X6
Whirlpool LUD2100X7
General Electric LUD3100V57WB Dishwasher
General Electric LUD3100V60WB Dishwasher
General Electric LUD3100V64WB Dishwasher
General Electric LUD3100X66WB Dishwasher
Bosch LV010-000
Whirlpool LV55
Whirlpool LV551
Whirlpool LV5511
Whirlpool LV651
Whirlpool LVA4000W0
Whirlpool LVA4000W1
Whirlpool LVA4000W2
Whirlpool LVA4000W3
Whirlpool LVA4000W4
Whirlpool LVA4000W5
Whirlpool LVA4000W6
Whirlpool LVA4000W7
Whirlpool LVA4005W0
Whirlpool LVA4005W1
Whirlpool LVA4005W2
Whirlpool LVA4005W3
Whirlpool LVA4005W4
  #2 (permalink)
Old 12-14-2009, 06:48 PM
Senior Member
Qtip is on a distinguished road
Default
The washer can run with 120. the dryer needs 240 to heat
  #3 (permalink)
Old 12-14-2009, 08:21 PM
Senior Member
Default
oh also i believe every brand dryer needs 240 to run the heater. i may be wrong on that and hope others will correct me on that if so but i really think every brand needs 240. washers only use 120 though
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool thin twin dryer belt instulation Dryermang Dryer Repair 2 07-01-2011 09:03 PM
washer issue Whirlpool thin twin (older) rchunter57 Washer Repair 1 02-24-2010 05:35 PM
leaking whirlpool thin twin washer trevorroehl Washer Repair 1 09-06-2009 05:21 PM
Whirlpool Thin Twin Washer Problem mineolabauer Dryer Repair 1 12-01-2008 08:45 AM
Whirlpool Thin Twin dryer will not heat bolingmike Dryer Repair 0 07-29-2008 01:42 PM
