| » troubleshooting help |
Model Number: 110.76520110 Brand: Kenmore Age: More than 10 years
I have an old Kenmore 220V elec dryer. It stopped dead, will not start. Breakers are OK. Door switch is OK. Apparently has NO thermal fuse that I can find. I believe it is either the motor or timer. Unfortunately timer is no longer available. I was wondering what anyone would recommend as far as testing the timer, and motor. Motor is common, still available (common replacement is). Also, can anyone date it?
Thanks John Ads By Google Related Models |
Some progress....
Bought a sears kenmore dryer repair handbook. Doesn't cover this exact timer set-up but some of the general continuity checks seemed to apply. On mine the push to start switch is built into timer, on one shaft. At terminals, between red and yellow, open with timer in off position. closed in run position. TPS terminal to either red or yellow open, pressing start switch, TPS to either red or yellow closed. Seems to be OK? Looks like either motor or something else. Will Ohm motor next. I would like to find the correct wiring diagram for this model, and still trying to date it. No thermal fuse means probably a little older. |
| Display Modes | |
| troubleshooting | georgep | Oven Repair (including Ranges and Cooktops) | 0 | 11-18-2009 08:23 AM |
| Troubleshooting | david8464 | Refrigerator & Freezer Repair | 3 | 10-03-2009 07:42 PM |
| maytag troubleshooting | jorgytj | Microwave Repair | 1 | 06-16-2009 10:09 PM |
| Troubleshooting ideas | noop71 | Refrigerator & Freezer Repair | 0 | 02-10-2009 09:55 AM |
| Dishwasher Troubleshooting | glennd | Dishwasher Repair | 0 | 01-08-2009 04:32 PM |
